Mexican block 347 built by Woody @ www.Fordstrokers.com
Probe forged SRS 14.2cc dish 4.030 pistons, Probe cnc beam 5.315 connecting rods, and a Cast Steel 3.400 Stroke Crank. ARP main studs, arp oil pump driveshaft,total seal rings & King brgs, Canton 15-620-S oil pan w/ pickup & dipstick.
To top all of this off will be a set of CNC 205 Trickflow heads setup by Jay Allen @ www.CamshaftInnovations.com , and the cnc port work was done by Total Engine Airflow (TEA). Jay Allen set me up w/ a nice Billet TLSR cam. I bought a nice set of Trickflow 1.6 roller rockers 7/16" stud mount, 7/16" rocker arm studs, and 7/16" guideplates. Trick Flow R intake w/ 90mm opening. Comp Cams 838-16 Solid roller link-bar lifters
I'll throw my current Vortech T-trim on it and see what she'll be able to do. Im kinda hoping for 650rwhp or so. Im sure this will get me pretty damn close if I throw 15-20lbs. of boost at it. He'll I made 505 rwhp w/ a stock motor & C.I. cam w/ 14lbs. of boost from my old S-trim. Im currently running 20lbs. w/ the T-trim on my car and will go to the dyno soon to get some new #'s. Im guessing 550-560rwhp. Thats why im building this new motor, cause this stock 110,000 mile longblock -cam isnt going to hold up much longer...
Lets just hope the Mexican can do it w/ some 7000rpm shifts
Compression ratio: 9.137:1
Accufab 90mm race version throttle body and egr delete spacer
Polished IAC valve
TFS valve covers
TFS R lower intake
TFS R upper intake
