Results 1 to 10 of 10
Thread: Ticking and squeaking
    Senior Member 95DropTop's Avatar
    Gibsonia, PA
    323
    My 95 vert has developed a strange noise that resonates through the driver's side exhaust. I noticed it after I put on the GT40P heads, some Mac headers, some crane cams roller pedestal rockers and made my own plug wires from an Accel kit.
    At first I thought it was just a misaligned collector at the header/h-pipe connection but now I replaced the h-pipe and still the same stuff happens.
    It sounds weird. Like a tick + squeak.
    The squeak seems to "almost" go away once the car is warm but the tick is still there. The squeak has me puzzled. It is not a solid squeal it is like "squeak, squeak, squeak... etc."
    WTF could it be?
    03 Cobra redfire vert - 466 rwhp / 456 rwtq
    Mods: Bassani Mid Length Headers, X Pipe and Cat Back, Accufab Big Oval Throttle Body And Polished Inlet Plenium, 2.95 Reichard Ultra Grip Pulley, MotoBlue Auxiliary Idler Pulley Kit, LFP Double Pass Heat Exchanger, K&N FIPK, C&L intake Pipe, 3.73 Gears, MGW Shifter, Spec stage 2 clutch, Fidanza aluminum flywheel, MotoBlue Hard Launch Bar, Full Tilt Boogie Racing kit and H&R Race springs
    Ligonier, PA
    6,365
    does it sound like a pipe is maybe hitting off something while driving? or is it sound like a small exhaust leak??
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Gibsonia, PA
    323
    Quote Originally Posted by 2001GTTT View Post
    It does not sound like a pipe hitting off of something. It is really noticable first thing in the morning when the car is cold (and when the air is cold).
    It happens less in the very hot summer (remembering from last summer).
    I suppose that it could be an exhaust leak.
    I snugged up the header on that side but all of the bolts were tight.
    Is there any sure fire way to find an exhaust leak?
    Is there any way that the valvetrain could cause some squeaking noise? I mean, all of the parts are bathed in oil but it sounds like it is coming from around the valve cover. I guess the header could be the culprit.
    Ligonier, PA
    6,365
    with my h-pipe the passenger side bolts on the header are extremely hard to get to, mine has a similar tick but its an exhaust leak due to me not being able to get that bolt in correctly.
    1991 BMW 325iX
    1978 Ford F150
    exact same problem I had, with my Mac Prochamber H.
    Matt
    94 Ford Ranger
    01 KX125
    2002 Ford Mustang GT - 13.96 @ 98.8 (sold)
    Jan 2008
    Jefferson
    4,674
    Call me crazy but maybe your rockers are ticking?
    Member torqueboxer's Avatar
    white oak, pa
    638
    stick or automatic? possible throwout bearing? push the clutch down and see if it goes away
    Gibsonia, PA
    323
    Quote Originally Posted by 97LaserRed View Post
    I am sure that they are but there is also a squeak. The squeak is the goofy part.
    Gibsonia, PA
    323
    Quote Originally Posted by torqueboxer View Post
    Stick. Pressing the clutch makes no difference.
    I got a mechanic's stethoscope and will start to poke around.
    I will probably record a video/sound clip and put it up for people to hear. It is a very big PITA.
    Jan 2008
    Jefferson
    4,674
    Quote Originally Posted by 95DropTop View Post
    yes get a sound clip that might be easier to tell.. i was also thinking TO bearing for the squeak but since you said pushing the clutch in make no differnce idk.
  1. Squeaking Noise - T5
    By 94Cobra in forum Fox-SN95
    Last Post: 11-06-2014, 06:37 PM
  2. Replies: 6
    Last Post: 06-19-2011, 10:21 AM
  3. Weird belt squeaking sounding noise..
    By Jper in forum General Tech
    Last Post: 11-19-2008, 10:30 PM
