Results 1 to 3 of 3
Thread: longtube headers
    Senior Member ebo 4356's Avatar
    Sep 2008
    California, Pa
    194
    longtube headers
    I have slp lm1s, but i want to buy longtubes and im worried its going to be way to loud. Are they worth it and do they increase sound alot.
    1997 Mustang GT- Sold
    MGW short shifter, Ford Racing 3.73s, JLT ram air intake, mach 1 chin spoiler, Off-road H pipe, Magnaflow Magnapacks, SCT X3 tuner, Full PI swap, steeda underdrive pulleys, 75mm throttle body, professional
    1999 Mustang Gt- On3performance 70mm single turbo, SCT ba2400 mass air meter, upr tubular k frame, upr front coil overs, 42lb injectors, walbro 255, kenne bell bap, pro 5.0 short shifter, 3.73 gears, Modular Head Shop stage 1 cams, SCT X3 tuner. Waiting on dyno tune!
    5,822
    IMO, the longtubes will have a more mellow sound than what you have now.
    Stock manifolds, off-road mid and SLPs have got to be the LOUDEST set-up with these mod motors.
    I got BBk longtubes, o/r x-pipe and magnaflow magnapacks (which aren't much diff than the LM1s) and I think it sounds great. There is no popping or crackling whatsoever. I was a little worried it would be loud as hell, but it seems like the LTs mellow, smooth out the noise some???
    I can't really explain it. Here's a short vid of this set-up: [ame="http://www.youtube.com/watch?v=BUEONPApYdo&feature=channel_page"]YouTube- 01 Mustang GT / short exhaust rev[/ame]
    edit: ARE they worth it? If you pay $600 for decent LTs for the noise factor, I would say NO that's not worth it. I would do cams at the same time. My car picked up about 40hp from cams and longtubes. I don't know how much the cams and/or lontubes would have been worth alone, but after doing some research, they obviously help each other make more total power. With your PI-swapped '97 block motor, you still should be able to run anybody's Stage 1 with no piston-to-valve problems, but you should do a lot of research on it.
    2019 Colorado ZR2
    Sep 2008
    California, Pa
    194
    Yea i was going to get LT's because im going to put a new clutch in soon and i heard you might as well get them while everything is apart.
  1. MAC Longtube headers and prochamber installed - 2003 Mach 1
    By 98saleen in forum Pictures & Videos
    Last Post: 03-24-2015, 08:50 PM
  2. FS: Mac longtube headers and midpipe for 3.8
    By SlowSix in forum Ford Vehicles
    Last Post: 08-14-2014, 08:23 AM
  3. Longtube install 95 gt question
    By Steve-0 in forum Fox-SN95
    Last Post: 09-14-2010, 12:28 PM
  4. Longtube help
    By 2001GTTT in forum SN95-New Edge
    Last Post: 02-09-2010, 11:21 PM
  5. BBK Longtube headers and BBK h-pipe for 5.0
    By WickedJester in forum Ford Vehicles
    Last Post: 06-10-2008, 06:25 PM
