Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 82
Thread: Opening weekend at PRP
  1. #61
    Sure send it to my email. Be nice to see how it launched
  2. #62
    3,316
    nevermind... i misread something.
  3. #63
    Everyone got 3 runs. Was an oil down I think the 8th pair out from start. That was an hour cleanup as they had to clean entire track thru shutdown. Few other smaller oil downs.
    My car ran ok. Ended up warmer then it was suppose to be today.
    1st pass
    60' - 1.651
    330' - 5.164
    1/8 - 8.077
    MPH - 82.43
    1000' - 10.581
    1/4 - 12.685
    MPH - 107.45
    Base timing at stock 10*, launch 5500, shift 5800, 12psi slicks, 41psi fronts, struts at #3, shocks both at #3
    2nd pass
    60' - 1.661
    330' - 5.139
    1/8 - 8.032
    MPH - 86.37 New best
    1000' - 10.514
    1/4 - 12.594
    MPH - 110.59 New Best
    Bumped base timing up to 15*, Launch 5700, shift 5800, struts at #3, shocks #3D/#5P, 13psi slicks, 45psi fronts.
    Car has turned 112mph before but it was in 40* temps and a 25mph tail wind. So with no wind today it's showing its making more power. As it responded nicely to the timing bump. If I ever get my tune it should run much better.
    My 3rd pass was wasted as 2-3 shift didn't go smooth and I wasted over a tenth at 330'. Even then it still pulled hard at top end and nearly ran 109mph on a crappy 12.92et
    It seems as though the 330' e.t. is a little off in relation to the 1320' e.t. Perhaps the stock cams were making a greater amount of avg. power at this point before the tune. I am not aware of how the combo was 330'-ing before the cam swap though. Any validity in the hypothesis stated?
  4. #64
    330' has been faster before. When I ran 12.47 and 12.48 last October it ran 5.0698/5.0733 330'. Which was best with stock cams and tune. Most my quicker passes are normally in the 5.0x range at 330'. I don't think todays passes were bad with new cams and stock tune. The fuel injectors are probably firing late. Those need to be firing alot earlier and possibly a little longer. Soon as I get tune for car I will need to put it on a dyno and go from there. I'm sure the shift points I was using are too low. Especially when I have no idea where peak power is at. These cams are capable of making power to 6800 on stock heads.
    Other thing is also I am at my 2-3 shift before 330' so if it's off a little or not playing nice with me. That will also slow me up a hair
  5. #65
    Senior Member stieny's Avatar
    Pittsburgh
    1,392
    Ares,
    I'm surprised you got to race at all considering how you almost killed that chick walking across the slick car lane.
    What I had to laugh the most about was the fact that she walked in front of you and then after you drove away she was the one that looked irritated even though it was her fault.
    Either way, car looked good.
    '15 CLA250 4Matic / AMG Sport
  6. #66
    Member fin1's Avatar
    Bethel Park
    81
    There were a lot more people watching than I expected. I guess everyone's ready for the season to start. The weather was nice but the few oil downs pushed the program out later than they planned. I had to leave before the gamblers race but at least I got two runs in.
    Brad
    PowerHouse Turbo: www.powerhouse411.com
    9.79 @ 135 1.36 60'
  7. #67
    Oct 2007
    3,125
    Quote Originally Posted by fin1 View Post
    Your car was hands down my favorite car there :)
  8. #68
    Quote Originally Posted by stieny View Post
    Ares,
    I should have fn hit her, give her a real reason to look irritated. She came out of no where and never looked. Kinda hard to miss the bright orange car coming at you.
    On a side note I got my tune...a day late. Updating tuner and getting it in. I'll have to get a date setup at dyno.
  9. #69
    Belle Vernon
    1,294
    Overall it was a good day other than some of the oil downs. The car ran descent, just have to tweak the suspension to keep the car from twisting so much.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  10. #70
    3,316
    Just to see if my psychic abilities are better than Miss Cleo's on 2 fronts, did they run slick cars first?
  11. #71
    No street cars. Most the breakage and oil downs came from street. Slick cars seemed to keep their troubles right at start line.
  12. #72
    Pittsburgh
    1,392
    Yea, thats what I said. It's not like your car blends in well. I'm interested to see how your tune works out for you.
    I thought it was ironic: we were talking to the guy that actually had the first oil down before the racing started. He had a GSX eclipse with a big turbo, direct port N20 and other things. He was commenting on how he bet that there would be a blow up within the first couple cars.
  13. #73
    3,316
    Thats comedy gold!
  14. #74
    Belle Vernon
    1,294
    BIG Negative, they ran street cars first. All the big oil downs came from the street cars and a monster truck acting like an idiot trying to dump the clutch at 8,000 rpms with 38" swamp mudders which anyone with brains would know that its going to destroy the yoke.
    The first and biggest one was a white conv foxbody. Something happened to him right after he launched but he decided to hammer the car anyway to run a 16.xx something then oil down the whole shutdown and return road. That there alone cost everyone a time run, so we could have had 4
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  15. #75
    Brighton Township
    1,665
    Well I said 11.5 or bust.. and it came true.
    Anyone that was watching could tell you the 11.5 didnt happen so go figure. Got a new best 60' with the new converter, 1.74 with more in it and ran a blistering 13.66@100 on that 60' lol
    Trans feels like it is dropping into N at the top of every gear, letting go and smashing the limiter. Going to drop the pan on Friday :(
  16. #76
    Sorry to hear about your trans, sk360. Been there before.
    Starting another thread with some pics...
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  17. #77
    Belle Vernon
    1,294
    Quote Originally Posted by SK360 View Post
    Yeah we have all been there. You'll get it figured out. The car looks great!
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  18. #78
    Brighton Township
    1,665
    Thanks guys :)
    [ame="http://s264.photobucket.com/albums/ii196/SK360_PGH/PRP%20Opening%20Day%202009/?action=view&current=3rdRunInside.flv"]PRP Opening Day 2009 :: 3rdRunInside.flv video by SK360_PGH - Photobucket@@AMEPARAM@@http://vid264.photobucket.com/player.swf?file=http://vid264.photobucket.com/albums/ii196/SK360_PGH/PRP%20Opening%20Day%202009/3rdRunInside.flv@@AMEPARAM@@vid264@@AMEPARAM@@264@ @AMEPARAM@@ii196/SK360_PGH/PRP%20Opening%20Day%202009/3rdRunInside[/ame]
    Theres an incar video of my 13.66@100 1.74 60' run, launch felt great but listen at the top of first and 2nd gear, not so great :(
  19. #79
    ouchh..didn't sound too good at all..sorry to hear that man..
    Matt
    94 Ford Ranger
    01 KX125
  20. #80
    Belle Vernon
    1,294
    man that is weird
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  1. prp opening
    By yeahloh95 in forum Drag Racing
    Last Post: 04-17-2012, 09:16 PM
  2. PRP Opening day April 3
    By CobraII in forum Drag Racing
    Last Post: 04-01-2010, 12:05 PM
  3. PRP opening day... guess the # of runs!
    Last Post: 04-04-2008, 07:52 PM
  4. Opening Day at PRP
    By molnartr in forum Drag Racing
    Last Post: 03-29-2008, 07:08 PM
  5. prp opening day!
    Last Post: 03-24-2008, 08:16 PM
