Results 1 to 8 of 8
Thread: Need to borrow 7/16" stud mount rocker 1.6
    I need to borrow just 2 of these rockers from someone locally.
    They have to be SB Ford 302 7/16" 1.6 roller rockers stud mount.
    Any brand will suffice.
    I just need to borrow them for maybe 2 days and then I will return them.
    I'm having valvetrain issues with my current TFS 1.6's and I want to see if it can be cured by using another rocker before spending $275 on a set if I end up not needing them.
    I really appreciate it!
    Thanks,
    Robert
    I have 2 you can borrow..
    978
    Harland sharp makes rockers just for the twisted wedge heads. They are intake and exhaust specific with the intake being offset to work with the rotated valve. There are two sets sitting in my garage right now but they are both hiding under valve covers...lol
    I can pull two off of my car if you want to try them.
    I'm still waiting to hear back from another source, if it doesn't fall through by today then I will drop you a pm. Thanks!
    Robert
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Rob, you still trying to verify your PR length??
    Yes, i'm coming up with some super long pushrod lengths and want to make sure it's not anything with my rockers. I have checked everything else.
    Here's the thread I have about the whole situation:
    http://sbftech.com/index.php/topic,16058.0.html
    I tried to look at your thread Rob and I see this message:
    An Error Has Occurred!
    The topic or board you are looking for appears to be either missing or off limits to you.
    Paul, There are certain sections of that board that you have to meet certain post counts to be able to view. I believe 99% of the minimum post sections are only 10 posts. You should make 10 meaningful posts over there so that the board will open up to you as there really is some of the best info out there for the SBF crowd.
  1. 1.6 ratio,7/16" stud mount roller rockers
    Last Post: 04-01-2010, 10:36 PM
  2. MEI 7/16" Stud Mount 1.6 Roller Rockers
    Last Post: 01-21-2010, 01:14 AM
  3. WTB 94/95 OEM Strut Mount Stud Plates
    By 94Cobra in forum Ford Parts
    Last Post: 08-08-2008, 02:41 PM
  4. Are these pedestal or stud mount rockers?
    Last Post: 04-17-2007, 01:39 AM
