i am getting black smoke. the map sensor is good. i replaced the fuel pressure regulator and also the 02 sensor. when the ignition is on the fuel pressure will not shut the fuel pump off yet when you open the fuel line at the regulator it has plenty fuel. you can also hear a hissing down inside the intake. can anyone please help. thanks fuel pump will not shut off i think it should in few secs after with key on!! any help appreciated
