Results 1 to 11 of 11
Thread: Roller rockers, push rods, stud conversion
    I have a set of Crane roller rockers, the stud conversion for E7 or GT40 heads and matching trick flow push rods. With this, you will have the correct valve train geometry with a Trick Flow stage 1 cam in a Fox. I am pretty sure the push rods are 6.500 long. I have to double check. There is about 700 miles on this stuff. I would like to get $250 for all of it. Over $400 worth of stuff here.
    They are 6.500 .080 pushrods. Just went to look.
    Pictures. So we all can see what they look like...
    Senior Member 95gts's Avatar
    Sep 2008
    Brownsville
    290
    Are they 1.6's? and would be using them on those gt40p's I got off of you on a 89 block, stock pistons, and f-cam
    95 Mustang gts... Cobra intake,GT40P heads, F-cam, sds efi, 60lb injectors, Garrett turbo 11lb's!!!
    Yes. I am not positive on the base circle of the "F" cam. You already have it huh? You would need to check once its together. If not, push rods are $80 from summit. Thats to get proper geometry.
    I just talked to a buddy of mine. He is 99% sure that length push rod will work with the F cam to give you the correct geometry. He has the same set up as you.
    UP...
    Still have these... All packaged up and ready to be shipped or picked up.
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Still got these?
    Sorry man. Sold them a long time ago.
    North Huntingdon
    1,136
    Ok thanks. If you come across any let me know. Looking to complete my top end.
  1. WTB - 42lb injectors & 1.6 roller rockers-stud mount
    By DeepJewel92 in forum Ford Parts
    Last Post: 05-17-2010, 11:24 PM
  2. 1.6 ratio,7/16" stud mount roller rockers
    Last Post: 04-01-2010, 09:36 PM
  3. MEI 7/16" Stud Mount 1.6 Roller Rockers
    Last Post: 01-21-2010, 12:14 AM
  4. How to install stud mounted Roller Rockers?
    Last Post: 10-18-2007, 08:57 PM
  5. roller rockers and push rods
    By 5k#Eaton in forum Ford Vehicles
    Last Post: 05-27-2007, 09:52 PM
