Results 1 to 20 of 24
Thread: Think I found some missing ET
    Opening day at PRP my car was off the entire way down track. About a tenth at 1/8 and 2 tenths at 1/4. Well on way home that day every time I came to a red light and had noticed the smell of brake cooking.
    Well $250 later I have new rotors, pads and calipers in the back. Passenger side wasn't so bad but driver side was FUBAR. I could barely turn the axle by hand and back side of rotor was messed up. Caliper was bound up bad. Car never pulled to a side but it does explain the drop in mileage also.
    Took a trip down McKnight road to break in pads and man the car just rolls so easy now. Should be interesting next trip to track with non binding brakes and a car thats tuned
    Uniontown
    1,792
    Should be a slightly better time slip coming then.
    Got Smoke?
    Looking forward to seeing what it goes now Ed.
    Yeah, that ought to make a difference! You sure there's not pieces of mop in there though???
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    i know guys that warp rotors, just so it pushes the pad away for less rolling resistance
    Belle Vernon
    1,294
    That might make a big difference Ed, you'll be surprised
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    I hope so if how its been driving last few days is any indication.
    I found mph. Ended up running consistant 111+mph. I could only get et down to a 12.51 with much better numbers down track than last outing. Running about same as my best back in October. Which makes it a solid mid 12.5 car in warm weather. After looking at a datalog of one pass I have found my shift light is WAY off.
    With MSD 2 step at 5800 my launch rpm held at 5827rpm. The peaks down track were way to low for where car should be shifted at. Shift light was at 6300. With light at 6300 and at 2-3 rpms were 5471 and 3-4 rpms at 5587.
    So it's off nearly 800 rpms. I had noticed last year that light would come on well before the traps and I only cross at about 5800-5900rpms. Last time I ever buy a Proform shift light. I'm gonna order up a multi stage shift light so I can get each shift setup with it's own rpm point. I'm sitting on atleast 3-4 tenths untill I get the shift points figured out. So a new shift light and a trip to the dyno is in order.
    I threw mine as far as I could when I figured out how frigged up it was. I have an Autometer with the pills now. Much more repeatable.
    You still have me well covered ;)
    That makes a lot of sense, Ed. Your mph should put you 12 teens easily. Though trying to judge you at the stripe with that mph at 12.50 would give people fits... it would be like Mikey with the T Type almost! :D
    Mikey... what shift light do you have???????????? Just wondering, with that 121mph trap speed.
    Bob, is that a temporary situation?
    ChuckT
    Sponsored by
    I sure hope so ;) I am still running low boost while I finish the tune. I do have an issue with the car not launching. Car hits then bogs, even at 6,000 rpm. Best 60' to date has been a 2.15. Working on a solution for that.
    I think I may have seen you up at the track Saturday Ares..
    Matt
    94 Ford Ranger
    01 KX125
    Oct 2007
    3,125
    Damn, that turbo must be pretty big to do that. You try slippin the clutch a hair to build some boost then side step it? I used to do something similar to that with my audi but that's a dinky k03 sport turbo. I wish I took that car to the track. I really got after it with that car LOL
    Mikey runs a Proform also Chuck.
    I have some video of a few of your passes Bob that Chuck got with my camera. You can see your car hit hard then fall on it's face then looks to get going again.
    Chuck let Barry know I will burn those videos for his son to CD
    Quote Originally Posted by MBH View Post
    That's what i've been saying ;)
    Clutches are binary in my world, off or on :D This is only a step to full on assaults and bald spots on the starting line. It just needs more RPM
    Yeah, it hit REALLY good, falls over almost putting me into the sterring wheel, then drives back through it. I'm still tuning on it :D
    Someone get me a copy of those vids if possible. We need to start swapping SD cards amoungst us or something.
    Belle Vernon
    1,294
    Yeah Chuck I run the proform shift light too but I dont have a problem with it. I don't even loo at the tach.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Mike, if you're going off the shift light, couldn't you be off like Ed was? Can you see the tach to see if it's coming on when you have it set?
    I just hope someone can film some passes whenever the Cutlass comes out. Car porn is good stuff. :D
    Test n tune is on for Sunday.
    ChuckT
    Sponsored by
    Belle Vernon
    1,294
    Chuck I think that the tach in the car is off and not the shift light. I atleast know that it is consistent when it comes on.
    We definitely need some video of the cutty when it is ready. Was that your camera that we were also using Chuck?
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    It is consistent, and so is Ed. Ed obviously has the mph for quicker ETs. I'm thinking that you might too... maybe not 10.90s, but darn close! :D
    I was mixing cameras between Ed's and Greg's. My dinosaur (matches my cell phone) I think needs a new battery.
    ChuckT
    Sponsored by
  1. missing posts?
    Last Post: 06-14-2014, 03:24 PM
  2. lightning missing
    By tylerstepp in forum Other Ford
    Last Post: 10-06-2007, 04:58 PM
  3. ok, what am I missing...
    By One Sweet Day in forum Pictures & Videos
    Last Post: 09-30-2007, 05:25 PM
  4. missing threads
    By J-rod in forum Site Announcements, Discussion & Help
    Last Post: 03-26-2007, 01:57 PM
  5. Am I missing something......
    By 1wykdmk8 in forum The Bar
    Last Post: 02-24-2007, 10:54 AM
