Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Think I found some missing ET
  1. #21
    Belle Vernon
    1,294
    I was wondering what you were thinking when you were relating the mph to the shift light haha.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  2. #22
    Jun 2007
    2,108
    Opening day at PRP my car was off the entire way down track. About a tenth at 1/8 and 2 tenths at 1/4. Well on way home that day every time I came to a red light and had noticed the smell of brake cooking.
    Well $250 later I have new rotors, pads and calipers in the back. Passenger side wasn't so bad but driver side was FUBAR. I could barely turn the axle by hand and back side of rotor was messed up. Caliper was bound up bad. Car never pulled to a side but it does explain the drop in mileage also.
    Took a trip down McKnight road to break in pads and man the car just rolls so easy now. Should be interesting next trip to track with non binding brakes and a car thats tuned
    Damn I wish I would meet you some time. I see you constantly out Rt.19 and Mcknight and by the time I follow you you are long gone. Love your car haha.
  3. #23
    Well I ran out to Summit afterwork and picked up a new shift light.
    Autometer #5348 - Black level 2 (peak rpm recall, multi shift point settings)
    Seems to be pretty nice setup and easy to use. I hooked it up to a small reciever battery pack for one of my RC cars and did a quick video of colors and shift points. Unit has a 4 wire hookup, black ground, red keyed power, green tach signal, blue for hooking to remote start/manual arm or brake/clutch switch or trans brake/line lock.
    Menu:
    PEAC = Peak RPM Recall (level 3 units have 80sec memory and playback to tach)
    SptS = Is menu for setting rpm for each shift point. Up to 4 settings
    LnCH = menu to set launch rpm light. (would be useful if not using a 2 step and not having to worry about watching tach when staging)
    PPr = Pulse Per Revolution, used for setting up to ignition type. (should be able to leave in factory setting)
    CoLr = For setting light colors. 0 = White, 1 = Red, 2 = Yellow, 3 = Green, 4 = Teal, 5 = Blue, 6 = Magneta
    L LV = light level, Lo can be set from 1-11 and factory is 1(easy to see), Hi can be set from 5-15(5 factory which is bright and 15 would be blinding at night)
    PSL = For Progressive shift light settings. I'm leaving this at factory off. I would think this toeasy to mess up a shift as it can be set to lite up in a color say at 60% to shift, then around 90% where is goes on-off-on, 100% at shift point then flashing red at over shift. The percentages can be adjusted to user. I think this would be good for road racing but I may mess with it at some point to see if I work with it.
    [ame="http://s222.photobucket.com/albums/dd256/mistwalker7/?action=view&current=Shiftlitefunctions.flv"]Shiftlitefunctions.flv video by mistwalker7 - Photobucket@@AMEPARAM@@http://vid222.photobucket.com/player.swf?file=http://vid222.photobucket.com/albums/dd256/mistwalker7/Shiftlitefunctions.flv@@AMEPARAM@@vid222@@AMEPARAM @@222@@AMEPARAM@@dd256/mistwalker7/Shiftlitefunctions[/ame]
  4. #24
    Belle Vernon
    1,294
    how much was it Ed
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
  1. missing posts?
    Last Post: 06-14-2014, 03:24 PM
  2. lightning missing
    By tylerstepp in forum Other Ford
    Last Post: 10-06-2007, 04:58 PM
  3. ok, what am I missing...
    By One Sweet Day in forum Pictures & Videos
    Last Post: 09-30-2007, 05:25 PM
  4. missing threads
    By J-rod in forum Site Announcements, Discussion & Help
    Last Post: 03-26-2007, 01:57 PM
  5. Am I missing something......
    By 1wykdmk8 in forum The Bar
    Last Post: 02-24-2007, 10:54 AM
