Results 1 to 12 of 12
Thread: Upper torque boxes
    Upper torque boxes
    Is there something "in the middle" for upper torque box reinforcment / repair? What I mean, is something more than these.....
    http://www.laurelmountainmustang.com/torque-LT.htm
    But not this extreme......
    http://www.wildridesracecars.com/newstuff.html
    My upper on the drivers side has pulled away from the floor pan. I believe it can be pushed back into place, welded, then reinforced with the "battle box" type plates from Lou, but would be interested if there is something better. The passenger side is still fine, and the lowers are okay too, but those suckers are all getting something added to them, and I'm a little concerned with the drivers side right now.
    Bob Myers
    i think the ones from lou and some extra welding will do the trick
    Senior Member 87notch's Avatar
    803
    LowHill
    2,679
    I got lowers to be welded on my car but know I need the uppers.
    Bob,
    There are pictures of the ones from Laurel Mountain in this thread after Tim @ Rodeheaver's welded them up in my car.
    http://www.steelcitystangs.com/forum...ead.php?t=1422
    Thanks! I should have updated this, I picked up a set from Lou a couple of weeks ago, still not installed, but they are here ;) Man I need to get get to work :D
    Bob Myers
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Send her out to Rodeheaver's & let Timmy work his magic.
    Corvette Z06
    you would be surprised at how much good welding all the seams under your car helps. add the boxes and weld the seams and you should be good to go. make sue to pull the carpet out before welding since there was a car that just went up in flames from NOT doing this. lost his car and part of his garage.
    I would get the battle boxes welded in and you should be good. I installed mine while doing the solid swap. Here are some pics.
    Painted everything with POR15 to prevent rust.
    Mt Pleasant, PA
    4,905
    Very nice weld job!!!
    Quote Originally Posted by EVIL1 View Post
    man thats a nice job, it really helps to have a newer car to do it to, when to do a car with factory undercoating it melts and runs into your weld and all over the place,,,and when you do a older car it is very tough to get the rust out from between the 2 panels...
    Yes,,,,a nice new clean undercarriage helps tremendously. Hardest part was all the sparks,,,couple times I thought I was on Fire. Plus I don't have a lift so I was laying on my back.
  1. subs and boxes
    By dpstang98gt in forum Ford Vehicles
    Last Post: 12-29-2009, 02:51 PM
  2. FS: 2 sub boxes
    By 97LaserRed in forum Ford Vehicles
    Last Post: 12-09-2009, 11:52 PM
  3. need:: 17" boxes
    By INSANELY CRAZY in forum Ford Parts
    Last Post: 04-29-2008, 05:14 PM
  4. torque boxes
    By pwtmxracing in forum General Tech
    Last Post: 12-31-2007, 10:43 AM
  5. free unused fedex boxes
    By 5k#Eaton in forum For Sale
    Last Post: 08-31-2007, 07:28 PM
