99 Trans Am.. Auto TTop Car..Bonnnee Stock
02 subie rex
Thats tuff u did that, from the looks of the LX in ur sig. It was badass!
Bu-2000-bash
ALLSQUAD
Steel City Muscle Cars
CarCruises
Flashlight Drags
NMRA
UMTR
Modded Mustangs
NHSCC
I just wanted something i can drive to the track and something newer.. Couldnt drive the lx to the track unless I used 100bucks in gas probably lol..But whats funny is I went 11.56 in that lx and from what I heard it just went 11.21 first pass out at prp.. Anyone know anything about that just curious to if he made changes or it just had more in it ?
02 subie rex
nice choice! throw a stall and some gears and bolt-ons and you my friend will have a nice 12 sec ride
Wow I can't believe you did that. Your stang was sweet! Am I the only true blue ford guy on here?
from what i could tell he had the exhaust opened up
Congratulations ;)
United We 'Stang2002 Mineral Grey V6 5-spdCount Your Blessings, not your Problems
I believe he said he made some changes plus he was leaving at about 3000 on the converter.
If you need any parts for the new T/A let me know - i have a few things laying around...
I have a K&N FIPK, driveshaft loop, 12bolt posi, Hypertech power programmer, and a ton of other things laying around.... They're just taking up space in the garage, so PM me if interested and I'd unload it for cheap...
I'd like to say "nice car" but i can't see the pics at work... good choice though!!![]()
2015 Corvette Z06
- Shark Grey / Kalahari
Congrats On New Ride But The Lx Was Mean!!!!
Marcus
2000 HD F150
1992 5.0 vert
5 speed
BBK SSI Intake
BBk 75mm Throttle Body
BBK Underdrive pulleys
BBk equal Length Headers
BBk O/R H Pipe
Flowmaster American Thunder exhaust
E303 Cam
24LB injectors
3:73 Gears
sweet ride
i've always been a fan of those cars. great choice man!
hi all,chuck here i bought the lx from ryan.it is DEFINITELY a bad actor trust me.just was doing some baseline runs.it never saw the converter on any of the 4 passes i made .bob was right.it pushed through the lights on the 2 passes i tried to flash the converter on.the drivers side rear wheel cylinder is leaking so that side had no braking on the line whatsoever.but regardless without a linelock you can't use the converter at all.the rear brakes get to hot from doing a burnout.the only thing other than uncaping it i did was plugs,wires,cap & rotor,oil change,new driveshaft(the old 1 was 3'' short),camber caster plates,line up,toe was out 1.5''(someone put coilovers on the front with stock plates)you can't properly line it up without adjustable plates.new tires all around.thanks mike
.i will bring it back out after i get the brakes squared away & a linelock.the cars best 60' was a 1.53 which is terrible.best et was 11.2400@119.49 sometime this year time permiting:i'll be putting roller rockers on it(it has stamped ones on it now)i was shifting @6000,after the rockers i'd like to shift at around 6600.the right size carb(it has an 800 on it now WAY TO MUCH),and 4.10's(it has 3.73's in it now)the car trapped out at 5800.which should be around 6800.ryan was running good #'s considering what he was had to deal with.someone built a very strong motor for this car but it needs massaged with a few $$$$'s then SPANKED.which i will readily dispense.right bob
? this car has 10's in it all day long.ryan was very honest when i bought this car.and i could'nt be more happy with it.THANKS RYAN
nice trans am.
CHUCK 87 TURBO-T 89 LX
Yeah, that thing really runs strong for sure. A few tweeks, line lock, and figure out where it will stall, and it's got 10's in it. i was actually suprised at the number it pulled off based on what it had run before and the "lousy" launches Saturday. I kid you not, the car was never on the converter, let alone the suspension, for those passes.
