Results 1 to 20 of 22
Thread: 99 gt won't start! any ideas?
    1st Stang boost_92's Avatar
    Dec 2008
    brownsville
    174
    Ok here's what happened......I was driving the car home from work with my new tune from Jon Lund on it and everything was running great. As I turned into my neighborhood and got on the throttle the tires started to break free and I shifted to second......I pushed in the clutch and the car stalled. As I tried to start the car it would just turn over but not fire. I ran my scan tool on the car and the code said (ignition/dist system malfunction) I do not have the code number cause I was in a hurry and erased the codes to see if the car would fire so I could get it home. Of course the car did not fire so I towed it home and contacted Jon Lund. He figured that one of the COPs malfunctioned and caused the ingnition fuse to blow. Well Yesterday I pulled every fuse I could find in the car and they were all good. Now I'm stumped and don't want to keep bothering Mr Lund.
    -Can anyone point me in the next direction I should head in narrowing down the problem.
    -Has anyone ever had this problem?
    Any help would be appreciated. I'm trying to get it back up and running before the next tuning day at wolfpack.
    Thanks
    1999 35th Anniverary Limited Edition! To many goodies to list! But cant leave out Mr. Kenne Bell!
    ~1 of 1259~
    Other rides:
    - 2003 Ford F-250 XLT Powerstroke (on 38's)
    - 2008 Subaru Imprezza STI
    - 2002 Ford F-150 7700 series (work truck)
    - 2000 Civic Hatchback (H22a) - SOLD
    - 1992 Accord Sedan (F22b Turbo)
    - 1995 Jeep Wrangler (lots of stuff)
    - 1972 Chevy C10 (lowered) - SOLD
    if it died that quick, i would check for crank signal and cam signal, is it not getting spark or fuel?
    Dec 2008
    brownsville
    174
    Not sure whether it's not getting spark or fuel yet. Gonna check that this week. How do I check the cam or crank for signal? My guess is that it's not getting spark.
    ~1 of 1259~
    Other rides:
    Member wicked400ex's Avatar
    Dec 2008
    Monessen, PA 15062
    89
    Did you check out that steeda timing adjuster to see if it was set at the stock setting? Is that sensor still in place and tight? Tim mentioned about crank signal, not sure if that's where it gets it or not. wondering if it may have jared loose from
    2008 Mustang GT (SOLD)
    2012 Black on Black Mustang GT Premium, MT82, 3.73, HID's, rear view camera, Brembo, Steeda, Lethal Performance, Flowmaster, SCT, Ford Racing Parts, Manley, ARP, Boss302, Mickey Thompson, Racestar Industries, BMR, M&H Racemaster, Pirelli, Energy Suspension, Stifflers, The DriveShaft Shop, Auto Meter, SOS, Raptor Performance, CFM. 11.89@118.30 w/1.75 60' 415.06/397.53 SAE/5
    Aug 2008
    State College PA
    2,326
    I'm sorry if this sounds stupid ..... but did you check your fuel enursha shut off switch?
    PICS & Dyno
    Dec 2008
    Monessen, PA 15062
    89
    Quote Originally Posted by mr4teth View Post
    Ya it sounds stupid, but it did happen to a friend of mines Escort GT back in the day! Where is it located on a '99 Mustang GT?
    Dec 2008
    brownsville
    174
    I checked it. That was my first move. the red button was not popped up.
    ~1 of 1259~
    Other rides:
    4,321
    Quote Originally Posted by boost_92 View Post
    Thanks
    Can you get me the actual code when you get a chance?
    Mike
    Quote Originally Posted by wicked400ex View Post
    In the trunk, on the left side I believe?
    Matt
    94 Ford Ranger
    01 KX125
    Dec 2008
    Monessen, PA 15062
    89
    Dan, Do any of the below codes look familiar? They are the ones I found that have the words you remember from the scantool.
    P0320 Ignition/ Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/ Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/ Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/ Distributor Engine Speed Input Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    Ligonier, PA
    6,365
    Quote Originally Posted by pRojekt02GT View Post
    correct.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    out in the woods
    4,948
    take the ford emblem off and put a bowtie on it, bet it starts right up...
    hahahahahaha
    BIG BLOCKS WITH TURBO'S turbo'dnotch's Avatar
    Apr 2009
    Myrtle Beach,SC.
    197
    hahahahahaha
    I will bet that the crank falls out of the bottom and the tape weights come loose from the brake calipers.http://www.camaro5.com/forums/showthread.php?t=19161
    Speed Kills....Play it safe and buy a CHEVY!!
    out in the woods
    4,948
    ^^^wooh thats really wierd..
    dan- is there any kind of alarm or remote start on the car? those run threw the wiring/ign etc... just a possable option.
    Do you run any sort of tach driver on the car? Like the Ford unit. I know if the wires from the timing pickup touch each other in any way car will just crank and not fire. I had that happen on mine when the connectors used opened up and the bare wires touched each other. Easy to over look.
    Dec 2008
    brownsville
    174
    It's fixed!!!!
    Thanks to all who have given their $.02. Last night John (wicked400ex) and I decided to start trouble shooting the car. Did the usual checks and were getting ready to flash the car back to stock tune when John decided to fiddle with the crank position sensor and as soon as he touched it the wire fell off. To the naked eye this seemed to be connected but actually was not. Once he plugged it in the car was ready to fire. Needless to say I secured the plug so that this doesn't occur again. Once again thanks to all who tried to help especially wicked400ex!
    ~1 of 1259~
    Other rides:
    Aug 2008
    State College PA
    2,326
    Glad to hear it worked out!!!
    PICS & Dyno
    out in the woods
    4,948
    nice. glad to here ya got it back up and running.
    Sweet, glad you got it fixed!
    Matt
    94 Ford Ranger
    01 KX125
    4,321
    Most of the time it's something silly like that! Glad you guys found the problem, talk to you soon
  1. Any Ideas?
    By 2001GTTT in forum S197
    Last Post: 04-13-2008, 10:58 AM
  2. 95 Gt Won't Start
    By 955.0 in forum Fox-SN95
    Last Post: 09-27-2007, 12:16 PM
  3. Car won't start
    By blkp42e in forum Fox-SN95
    Last Post: 09-09-2007, 02:59 PM
  4. 95 won't start when cold
    Last Post: 08-14-2007, 10:22 PM
  5. Replies: 16
    Last Post: 09-24-2006, 04:53 PM
