Results 1 to 14 of 14
Thread: 5.0 guys please help.
    I have spent 2 weeks trying to figure this out. Any knowledge/advice is greatly appreciated.
    Ill try to explain in detail.
    Car is a 94 cobra.
    Built motor
    347 stroker
    stock block .040
    probe pistons
    scorpion rockers
    e-cam
    70mm throttle body
    cai
    bbk headers
    straight 3 inch exhaust
    -over the past two weeks the car began to miss around 2 grand
    -it would happen once or twice a drive so i changed the plugs and wires
    -next time the car was out problem got much worse
    -in gear or neutral the car seems to be missing throughout all rpm's
    -car was parked immediately and since i have changed
    plugs
    wires
    tps "yes its set where it should be"
    coil
    distributor cap
    fuel filter
    timing is where it should be
    idle is almost normal but jumps around a slight bit
    i have basically checked my entire wiring harness
    cleaned maf
    found a slight leak in my upper intake gasket but fixed that
    do not seem to be any loose grounds
    so start to finish. if i got in the car right now. it would roll over just fine. idle would stay around a grand and suddenly decide to jump to around 1900 and back down about 2 seconds later. if i ease on the gas from idle everything is normal till around 2500 rpm's. if the gas is held at 2500 the car will just sit there and misfire and the rpm's will sit and twitch. same thing at around 2900, 3500, 4000. under the hood, everything sounds/appears to be fine. at the above given rpm's it seems i can hear a slight pinging coming from the pipes.
    i scanned the codes
    two dont seem important
    egr signal too low
    evap emissions out of range
    and the third code is closed throttle position out of range
    any possibilities guys/gals?
    hopefully nothing internal.
    pip sensor in distributor possibly?
    injector?
    cant work on the car until sunday, and next step will be to check fuel pressure, and compression.
    ANY HELP IS GREATLY APPRECIATED
    State College, PA
    3,552
    change TFI module and if that dont work maybe you need a new distributor. also your ECU could have gone bad but i highly doubt it
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    FAST WIT A FORD OVAL 90TitaniumStang's Avatar
    Feb 2009
    Latrobe
    517
    problem
    my 90 was doing the same hting also you might need it tuned take it to wolfepack and have mike tune it
    1989 GT Black,full 16 pt MOLY 8.50 CERT.
    461w Dart block w/ 4 bolt-all 5 caps
    EAGLE PENDULUM CUT ESP ARMORED 4.250
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    vac. leak? I had one of the vac. lines under the intake fall off. I had similar symptoms.
    2015 GTPP
    pa
    860
    Its the pick up in the distributor. been there, done that. swap the dis and you will know right away.
    BIG BLOCKS WITH TURBO'S turbo'dnotch's Avatar
    Apr 2009
    Myrtle Beach,SC.
    197
    Quote Originally Posted by ddmi-twin90gt View Post
    +1 although some things can act the same.
    Speed Kills....Play it safe and buy a CHEVY!!
    Spencerport, NY
    3,762
    +2 ... i'd suggest this first as well...
    right before I sold my '94 Trans Am, it was having a similar issue. You could smash the pedal to the floor in P and it would get to about 3000 rpms and then sound liek it was hitting off a rev limiter... the distributor was so bad that the engine couldnt even make any more revs
    If its not distributor, check fuel system (filter, injectors, etc)...
    2015 Corvette Z06
    - Shark Grey / Kalahari
    distributor it is. i figured. i tried everything else but fuel problems. filter was just changed. if distributor does not do the trick. im gunna move on to new injectors. still lookin for a distributor for a 5.0 if anyone has one laying around w/ low miles on it. $$$
    well. changed out the distributor today. and problem is fixed. i gotta say, after changing everything little frikin thing in the car over the past 2 weeks. it runs pretty darn good.
    pa
    860
    Quote Originally Posted by schiavo8241 View Post
    See, I told ya what it was. Now I'll take a beer for payment!
    here ya go!
    Apr 2009
    Myrtle Beach,SC.
    197
    here ya go!
    WOW, I would at least thought Corona or something!!!
    Mt Pleasant
    2,916
    glad to see you got it running
    Quote Originally Posted by 92306gt View Post
    thanks again man. made a post in the good transactions. appreciate it.
  1. Sorry guys.
    By AutomagicSN98 in forum Pictures & Videos
    Last Post: 07-24-2012, 11:23 PM
  2. You guys...
    By Wolfpack Speed in forum Wolfpack Speed
    Last Post: 04-22-2011, 12:46 PM
  3. 4.6 Guys LOOK!!
    By How Much? in forum The Bar
    Last Post: 12-13-2010, 08:24 PM
  4. 94 95 guys i need some help
    By 94gt5.0 in forum Fox-SN95
    Last Post: 10-28-2009, 11:59 PM
  5. What do you guys think?
    By coralcoupe1993 in forum The Bar
    Last Post: 05-14-2007, 11:30 PM
