Thread: 4 cyl front hubs?
    4 cyl front hubs?
    are they the same as 5.0 cars? i am looking at 5 lug kits and was wondering if i need to switch to 5.0 parts first? i may just go sn95 if that is the case? thanks for any hlep
    Troy - 95% confidence in this..........
    Early fox (four eye cars) and 87+ 4 cylinder cars had the same spindles.
    87+ V8 cars had a different spindle.
    SVO is unique
    87/88 Turbo coupes will work too.
    I would go right to the SN95 stuff and have wheel choices too ;)
    No
    The older stuff pre 86 was same 4,6,8 they changed caliper size then, but 87 up the v8 cars had larger spindles
    JUNK IT!
    SVO is unique
    sorry bob, didnt see you explained, Yea, go with what he said
    JUNK IT!
    LowHill
    2,679
    Troy, stay away from those 5 lug kits offered for crazy money. they are basically lincoln rotors and ranger axles and they charge way too much. Like Bob said just do SN 95 unless you know exactly what wheels you want to use then there may be a easier way also
    i have been looking at wilwood kits ,just not sure what spindle they use? i guess it might be a v8 one?? thanks guys
    Troy, the Wilwood kits use the Fox V8 spindles. You have to cut part off and tap new holes. I did one of their kits on my 88 GT. It worked really nice to convert the front over to 5-lug.
  1. 94-95 sn95 spindles and hubs
    By TooFast98Cobra in forum Ford Vehicles
    Last Post: 11-06-2014, 04:32 PM
  2. Replies: 3
    Last Post: 11-02-2011, 12:05 AM
  3. WTB 94-95 Spindles+hubs
    By TooFast98Cobra in forum Ford Parts
    Last Post: 04-07-2010, 12:54 PM
  4. FS:front/rear black 4 cyl seats hatchback
    By 1badnotch in forum Ford Vehicles
    Last Post: 07-28-2008, 04:37 PM
  5. Wanted Fox Body 4 cyl front sway bar, brackets
    By wht88cpe in forum Ford Parts
    Last Post: 04-06-2007, 06:50 PM
