Results 1 to 12 of 12
Thread: 3G alternator upgrade questions
    State College, PA
    3,552
    Question 3G alternator upgrade questions
    i have some questions on wiring my 87 for the 3G upgrade.
    1.) i cut the power plug off. i solder the yellow wire from my car's harness to the small connector with a white wire that came off of the 3G. correct?
    2.) should i put ring terminals on the black/orange wires and put them on the power stud WITH a 4 gauge wire also on the stud that goes to the starter relay.
    OR
    should i tape off the black/orange wires and just run the 4 gauge wire for power?
    2013 Mustang GT
    1999 Contour SVT
    Follow those "two" black/orange 10awg wires about 12" to the connection where they, for some stupid reason, merge into 1, cut one of them off and put a ring terminal on the other. Use some 4awg as a supplement for the higher amperage and go straight to the "hot" side of the started relay with it.
    State College, PA
    3,552
    thanks for the tip. wasnt sure if i should keep the factory wires on with the 4 gauge wire as well. and was i correct about the first question? is that what i am supposed to do with the yellow wire?
    2013 Mustang GT
    1999 Contour SVT
    I cant remember about the yellow wire. I know the stator wire comes out of the regulator side of the alternator. I just cant remember the yellow wires significance.
    NEWB daviac5000's Avatar
    Cheswick, PA
    124
    Just run the 4 Gauge wire. If your fuse blows you don't want all the power going through the 10 gauge wires.
    Dave
    Quote Originally Posted by daviac5000 View Post
    Dave
    Do you really want to be stranded though?
    State College, PA
    3,552
    Dave
    good points from both of you guys. maybe if i have an extra fuse in my car ill leave it off, otherwise ill have both connected
    2013 Mustang GT
    1999 Contour SVT
    Cheswick, PA
    124
    If you blow a 150 amp fuse, you probably have an issue worth looking at immediately.
    State College, PA
    3,552
    hahaha yeah that probably wouldnt be good!
    2013 Mustang GT
    1999 Contour SVT
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I would also suggest you upgrade the grounding from the motor to chassis. I don't know of the battery to chassis also needs to be upgraded.
    Quote Originally Posted by DRRummel View Post
    X2!!!!! - Any EEC 4 car can benefit from ground upgrades for sure.
    State College, PA
    3,552
    thanks for the tip. so maybe a ground from say the block to the firewall would be a good one to use?
    2013 Mustang GT
    1999 Contour SVT
  1. I need a 3g alternator
    By White5.0 in forum Ford Parts
    Last Post: 10-27-2010, 10:13 PM
  2. 4.6l alternator
    By pRojekt02GT in forum Ford Parts
    Last Post: 11-27-2009, 04:49 PM
  3. Alternator Help!
    By pRojekt02GT in forum SN95-New Edge
    Last Post: 10-27-2009, 05:10 PM
  4. alternator
    By sinful rides in forum Ford Parts
    Last Post: 10-07-2009, 09:25 AM
  5. 3G alternator
    Last Post: 08-05-2007, 09:20 PM
