Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: TnT last night 5/7
  1. #21
    Chuck is this one gonna be a belt eater also? You better have aligned those pulleys or
  2. #22
    Thanks, Ed, you jinxed me.
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  3. #23
    Doh, never did see your run but was so wrapped up in my own little world that I didnt even think that you had a problem.
    Man was that headwind nasty.
  4. #24
    Ok Chuck you run an electric fan right? Also your crank pulley, is it the larger factory one or the smaller factory underdrive type? I ask as my 350 Olds I had before had the smaller factory crank pulley and never ever tossed a belt.
    How bout we set that bad boy up with an electric waterpump. Then ditch any other accessory and use a 6rib short belt system to spin the altenator, similer to how Mikey has his. No more tossed belts and cooling system will work better. It's win win.
    or
    You're gonna have to use a large diameter deep groove altenator pulley to A: slow down the speed of it and B: keep the belt in groove. As V belts are the suck.
  5. #25
    Bob, I didn't make a pass. On the drive out, I discovered the shifter cable needed adjusted, and the belt was wailing more than Balaska about rain. I would have tossed it had I tried to run. So I adjusted the cable there and just watched.
    Ed, stock 1969 pulleys. I think it's the alt bracket. It's 2 pieces. When the car was slower, I was able to run with just the one piece. Hundreds of passes at 6000 rom later, I think it may have bent it forward to where it is now. I'm going to take the bracket off of the parts car and see if that helps. I do have a deep alt pulley if it comes to that.
    I've thought about a Meziere, but that's out of budget for awhile.
    ChuckT
    Sponsored by
  6. #26
    Ok thats funny
  7. #27
    Belle Vernon
    1,294
    Someone has to do it
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  1. friday night tnt
    By john123456 in forum Drag Racing
    Last Post: 07-21-2014, 09:07 AM
  2. Anyone going to qcr 9/26/08 for tnt?
    By orange 500 in forum Meets & Events
    Last Post: 09-25-2008, 05:12 PM
  3. Tnt 6/25???
    By travj31 in forum Meets & Events
    Last Post: 06-29-2008, 06:46 PM
  4. TnT 5/28
    By Martin0660 in forum Drag Racing
    Last Post: 06-01-2008, 08:34 PM
  5. TnT tonight
    By somethingclever in forum Drag Racing
    Last Post: 05-09-2007, 05:56 PM
