I have a complete 5 speed swap for a Fox body with many new parts. You will get a used T-5, a Quick time non SFI steel bell housing and block plate, A Ram Powergrip clutch, A Ram flywheel, A Steeda Tri-Ax shifter, Steeda Clutch quadrant, Steeda clutch cable, Steeda firewall adjuster, Clutch and brake pedals, steel driveshaft, and the wiring jumper for the 5 speed stuff. The Bellhousing, clutch, flywhhel, and most of the Steeda stuff has around 20 passes on it and about 200 street miles. It is all still in the car. You can drive it before I remove it. The only thing you will need to buy seperate is a pilot bearing. $1500.00 724-516-1605
