The FR linkage is about one inch short of lining up. There definately doesnt look like I can make an inch up in the linkage. Does the factory shaft that comes through the firewall slide at all? I tried pulling on it without any luck.
2015 GTPP
It will slide, it did on the 87 unless air bag cars are different ???
I thought so, but this thing doesnt wanna budge.
2015 GTPP
The shaft that actually passes through the firewall will not slide. Are you sure you have the correct shaft? They are different for manual and power racks.
if you are usingt the factory shaft the special knuckle is needed from flaming river
PROBE PISTONS
PROBE BILLET I BEAM
super victor
230cc CNC
Hooker 2 in headers
pa sc c4, 4600 stall
9" LADDER 3.70 PRO GEARS
SW BACKHALF
moser 35 SPLINE axles
1050 RACE DOMINATOR DEMON
250 FOGGER KIT
snow performance stage 2
1.316 60ft 9.16@156
I thought the shaft that came with the FR kit was long on all of them?? When I ddi mine the shaft needed to be cut by some amount. Troy gave me a dimension, we mocked mine up, and he was right.... but I can't remeber what it was.
Anyway, did you cut the shaft? Only other thing i can think of is as Ed suggests, it's the wrong shaft.
Thanks guys. I bought the entire setup (rack, shaft, endlinks) from Silvernotch, and he had it working on his car. I dunno.
2015 GTPP
is it the adapter shaft or the full replacment ?
full replacement
2015 GTPP
Mark Lowry
Mark Lowry
That damn shaft would not slide.
I pulled the steering column out, pulled the shaft that runs thru the firewall out of the column, and its all good.
Thanks guys.
2015 GTPP
