Results 1 to 20 of 38
Thread: Summer Garage Cleanout !
    train kept a rollin! thebreeze72's Avatar
    Jun 2008
    u-town
    343
    Cool Summer Garage Cleanout !
    1. complete 1990 LX 5.0 hatchback 5spd,8.8, titainium frost ext. grey int . 65k mi. salvage cert. car. $1600.00
    2. complete new 9" ford rear for foxbody see www.racingjunk.com add # 1562564 $2500.00
    3. complete 89 5.0 HO engine 48k mi. $400
    4. complete disassembled 5.0 HO eng.$220 (shortblock intact.)
    5. 1988 5.0 HO T-5 trans. 55k mi. $450.00
    6. set of 4 strange coilovers (stock mounting)$350.00
    7. WOLF RACECRAFT control arms :double adj. uppers,single adj. lowers that are offset for coilovers & no perches$300.00
    8. complete 93 t-bird w/5.0 HO & aod-e $500
    9. 5.0 HO flywheels: ford motorsport billet $200.00 new in box . stock;used but fresh cut $80.00 ,used $60.00
    10. complete 1971 ford 302 mexican shortblock $600.00
    11. C-4 TRANSMISSIONS: 2- 66'S FOR V-8 $100.00 EACH 1.65 6cyl $75.00 1.new 28oz 157th. SFI flexplate $60.00
    12. 66 Ford 3spd. toploader trans. w/alum. tailshaft $100.00
    13. new. flowtech 2 1/2 h-pipe for full length headers $150.00
    14. MSD 6AL digital box w/wiring&conn. like new $175.00
    15. dry nitrous kit for 5.0 HO 100hp. w/blanket,purge,bottle heater ,all lines ,switches,conn. ,10lbs. bottle, and gauges. $300.00
    16. barry grant 280 gph black pump w/fuel filter, mounting bracket , and complete braided line's tank to regulator $300.00
    17. barry grant 950 cfm. drag demon carb like new $500.00
    18. brand new in box 351w eldebrock super victor intake $300.00
    19. complete set of 16 isky redzone solid roller lifters used $300.00
    20. used eldebrock 351w victor jr. fully ported $200.00
    21. MSD 351w billet dist. like new $150.00
    22. milodon 351w foxbody oil pan&p/u tube used fits girdle $175.00
    23. set of new kenny brown for 83-88 t-bird castor/camber plates $100.00
    24. brand new in box ford motorsport X303 hyd. roller cam $150.00
    25. complete 93 fox k-member w/susp.&stering $100.00
    26. WHEELS:2 sets of 4-10 hole lx 4-bolt rims w/centers $125.00 each .set of 2 really nice turbine rims w/ good tires $50.00 1. turbo coupe aluminum 4-bolt spare $50.00 2. 5 bolt doughnuts $30.00each
    27. MOTORCRAFT 2V AUTOLITE 2100/2150 CARB. KITS $30 /$35 EACH .
    28. 5.- 255/70/17 TIRES (GENERAL AMERI-TRAC )3 GOOD 2 SO/SO $50.00 TAKES all
    29. 4R70W/AODE shift kit $20.00
    30. 1987/88 5.0 HO 5spd. speed denisity pcm $100.00 , 87/88 . 5.0 auto -sefi- pcm $50.00
    31. set of new in box 8.8 31spline FORD RACING 5bolt axles w/studs for foxbody w/drums $300.00
    32. 64 1/2 to 66 mustang gt rear bumper valance $75.00
    33. 302/351w carter hp mechanical fuel pump 500hp rated $40.00
    34. 94-95 5.0 HO T-5 complete w/bell&fork 38k mi. $550.00
    35. complete 93 lx coupe sound deadner&insulation $50.00
    36. complete 93 mustang hvac w/ all vents&duct work $100.00
    37. 93 mustang a4ld auto shifter w/ cable $25.00
    38. 93 mustang 4cly. auto pcm& conn. $25.00
    39. 2.)complete 8.8 3.27 4-bolt ,posi. rears $250w/drum $275w/disc
    40. 5bolt front brake fox conversion $50.00 for everything.
    41. grey 87-93 rear hatch int. panels 5pc. $75.00
    42. new in box ford motorsport 4.10 ring&pinion $140.00 , used 3.27's $40.00 2.73's free to good home
    43. front timing cover 289/302/351w for mech. pump $40.00 ,5.0 elec. fuel pump $40.00 , explorer front cover w/water pump $50.00
    44. HOLLEY new in box 190 gph elec. fuel pump $100.00
    45. MAC aluminum underdrive pulleys new in box $75.00
    46. euro tail lights for fox $100.00
    47. 79-93 SALEEN whale tail rear spoiler w/brake light $200.00
    48. 79-93 SALEEN front bumper cover $250.00
    49. 85-86 GT front bumper cover $150.00
    50. 82 gt front bumper cover $50.00 call dave (724)425-1911
    Gibsonia, PA
    323
    PM sent on item 3. complete 89 motor
    Nov 2008
    ELIZABETH TWP.
    885
    pm sent on item #16 barry grant fuel stuff...
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
    Jun 2008
    u-town
    343
    sold items!
    item #3 sold ,item#15 pending!
    whats up Dave?? Did you see that Cossells is opening the biggest mustang junk yard aon the east coast in uniontown?? Its gonna be at Benders old speedway garage..
    LowHill
    2,679
    He tried that at West Alexandria and had a bunch of tools working for him. I went there and asked if they had any Foxbody cars for parts and they had no idea what I was asking for.
    Anyway, Dave I will pick up that rear tomorrow after work.
    Jun 2008
    u-town
    343
    Cool update!
    items# 5,41 sold item 49 pending!
    Jun 2008
    u-town
    343
    Cool updates!
    item #15 sold , item#49 still for sale.
    2,483
    edited
    Jun 2008
    u-town
    343
    Wink a few price drops!
    items #47 $150.00 #48 $200.00 #49 $100.00 this stuff has to go!
    dude thanks for the deal on the rear parts for my interior
    Jun 2008
    u-town
    343
    anytime!
    just tryin to clean out my garage somtime soon!
    The Man bigmack's Avatar
    Monroeville
    95
    pics of car please
    Jun 2008
    u-town
    343
    Cool sale pending on car !
    if it doesn't sale send me your email i'll send you some pics asap!
    Jun 2008
    u-town
    343
    updates!
    item # 16 sold items# 18,19,21,22,23 pending !
    Jun 2008
    u-town
    343
    Cool update!
    Item #23 sold
    Jun 2008
    u-town
    343
    Cool bump!
    make offers!
    Jun 2008
    u-town
    343
    Update!
    Items #39,48 Sold!
    Jun 2008
    u-town
    343
    bump!
    lets deal this week end !
    Jun 2008
    u-town
    343
    Cool update!
    items #14,18,19,21,22 sold!
  1. Garage Cleanout
    By dGrabber in forum Ford Vehicles
    Last Post: 04-10-2013, 06:30 AM
  2. HUGE garage cleanout
    Last Post: 11-06-2011, 08:07 AM
  3. Garage Cleanout part 1
    Last Post: 10-23-2011, 10:34 PM
  4. Garage Cleanout
    By jaa55 in forum Ford Vehicles
    Last Post: 02-11-2010, 11:05 PM
  5. 2009 garage cleanout part #2!
    By thebreeze72 in forum Ford Vehicles
    Last Post: 11-24-2009, 12:14 PM
