hey im mark,got 92 gt &89 saleen,from export pa.
welcome
on 92 i put on intake spacer but now makes whisle noise since.can anyone lead in right direction?but it runs great
Welcome to SCS!
Mark
LeMans Blue Z06
Welcome!
How well did the spacer match up to the ports in the intake? If there was a "step" the sound you hear could be turbulent air. Also, are you sure that you don't have a vacuum leak after the install? Most often that is the cause of a whistle type of sound... well that and BBK throttle bodies. :)
Welcome!
That is ALWAYS a good idea. Turbulence is bad and should be avoided at all cost. I spent a number of hours yesterday grinding on my stock cobra lower intake to get it to have a nice/smooth transition between it, my felpro 1250 gasket, and AFR 165 intake port. The result was almost seamless!
welcome
welcome to the site..you live right down the road from me. I haven't seen your cars around tho...
