Results 1 to 3 of 3
Thread: 86gt AC compressor
    2,247
    86gt AC compressor
    I was trying to figure out why my AC said it was charged but didn't blow cold air. Then i noticed the belt runs over the AC pulley, and then the outside of that spins on its own? It will turn on every 10 seconds or so for about 2 seconds then shut off. Has any one else had a similar problem? Do i need a new compressor?
    Black
    Cheap SOB
    Baltimore, Maryland 21236
    288
    As the AC compressor runs the high side of the system increases pressure and the low side drop in pressure. If your refrigerant is low, the low side will drop enough that the High/low pressure switch will kick in and disengage the compressor. The idea is that if the pressure is low enough you don't have enough refrigerant/LUBRICATION in the system and you might damage the compressor. After it switches the compressor off the two sides of the pressure system start to balance out again. As the low side increases pressure, the kill switch resets, and the compressor start up again, repeating the cycle.
    Can you get your hands on a set of manifold guages? Some pressure reading would be helpful.
    If you are sure you have enough refrigerant, check the power to the clutch. If it is cycling also, it is in the harness or pressure switches. The the AC clutch power is constant, the AC clutch would be suspect.
    Boat's and Hoe's fordandmopar21's Avatar
    Aug 2008
    226
    Mine does the same thing, the little outside piece wont spin? If so then yeah you need a new compressor.
    Justin
  1. HELP! 86GT lost keys!
    By Shorty429 in forum The Bar
    Last Post: 08-15-2012, 12:39 AM
  2. 95GT alternator on 86GT
    By Shorty429 in forum Fox-SN95
    Last Post: 02-08-2012, 07:14 PM
  3. Just seein if i can post my vids!!! 86gt burnout
    By How Much? in forum The Bar
    Last Post: 08-22-2010, 11:31 AM
  4. Air Compressor
    By lib88stang in forum For Sale
    Last Post: 01-27-2009, 10:05 PM
  5. WTB, grey 86GT interior parts
    By itow in forum Ford Parts
    Last Post: 12-06-2007, 11:38 PM
