[ame="http://www.youtube.com/watch?v=qCK7N2SgJjE"]YouTube- 1985 IROC Z28 BRAND NEW[/ame]
http://www.thirdgen.org/techboard/hi...mile-iroc.html
What a find. Your thoughts?
Chris
2016 Chevrolet Volt
2010 Jetta TDi Cup Edition
1964 Lincoln Continental
wow that is awesome... The third gen camaro has been growing on me alot...
I had a 91Z28 with the L98 350 TPI engine. It was the first year for the return of the Z28 since the early 80's I think.
Had it for a few years. Unfortunately it never grew on me like the 5.0's, but it was a great car. Tons of torque and handled real well.
The car in the vid has a 305 as you couldn't get the manual trans with a 350.
Anyone have vid of this car cleaned up or know what happened to it ?
I had an '85 305 Iroc-z with some type of special factory handling setup, car was on rails in the twisties. Run fairly well too. A buddy has an 25th anni Z28 with about 1600 miles on it. Everything still has the plastic on it as well. This one is prolly so screwed up with the tank, fuel lines, injectors, brake lines etc., would be a nightmare to get it road worthy.
It says in that thread that it ran and idled after initial startup. And as far as I know when it comes to IROC's, you can get a 350 with a 5spd but it had no t-tops because the torque would twist the car and pop the t-top's off.
Chris
2016 Chevrolet Volt
the z28 was made while they had the iroc also,they never made a 5.7 5spd because the tranny's would never hold!
wow thats crazy. definatly would be a nice find
[ame="http://www.youtube.com/watch?v=dZ7wpCvPZzw&feature=PlayList&p=4680A174D7D 2171D&playnext=1&playnext_from=PL&index=17"]YouTube- Static-X Z28 "CULT OF STATIC"[/ame]
Static x.... z28! the stingwray video is good too lol![]()
If its an '85 LIKE THE ONE I OWNED, its tuned port injected. It had a throttle body.
http://images.google.com/imgres?imgu...a%3DG%26um%3D1
Furthermore for the 5.7 and 5-speed. I had one and here is documentation of them being built. Believe me or not, I really dont care.
G92 option included N10 performance exhaust system (dual catalytic converters) which increased power output by 13% on cars so equipped. For 1989, G92 also required the following options:
- 5.7 TPI motor (B2L) or 5.0 TPI motor (LB9) with 5 speed (MM5) manual. 16 inch wheels (N96) P245/50ZR-16 Goodyear Gatorback tires (QLC) Limited slip differential (G80) Rear disc brakes (J65)
- Engine oil cooler (KC4)
G92 and J65 (rear disc brakes) no longer available on IROC-Z convertible.G92 and J65 (rear disc brakes) no longer available on LB9 automatic IROC-Z.1LE performance package option (option level 0 IROC-Z) became more well-known.
1LE package was obtained by ordering the following:
- Level 1 IROC-Z with 5.0 TPI engine with 5 speed or 5.7 TPI engine Optional axle ratio (G92) (305/3.45, 350/3.27) and its required options.
- Air conditioning delete (C41) (standard heater)
Then the 1LE performance package was installed consisting of:
- Fog lamp delete Aluminum driveshaft (JG1) Performance exhaust system (N10) (dual catalytic converters) Special deflected disc shocks Aluminum spare wheel with smaller spare tire (N64) Larger (11.86 inch) front rotors with Girlock or PBR Australian built HD front dual piston aluminum calipers Special swinging fuel pickup in gas tank and special 18 gallon baffled fuel tank for fuel pickup down to .5 gallon reserve to prevent fuel starvation in hard cornering.
- Some came with special 16x8 light alloy mesh wheels. (XWL)
111 1989 1LE IROC-Z's were produced.
A new progressive throttle linkage was added to give smoother initial acceleration. The throttle had a smaller rate of advance at beginning of travel, and a larger ratio as the throttle was depressed
1989 Chevrolet Camaro Drivetrain List
Yr Model Trans Engine
code/type CR Displ. HP Torque Induc-
tion Manual
std. Manual
opt.
(G92) Auto
std. Auto
opt.
(G92) 89 RS
Firebird M5,A4 LB8 V6 8.9:1 2.8 (173) 135@4900 160@3900 MFI 3.42 ---- 3.42 ---- 89 RS
Firebird M5,A4 LO3 V8 9.3:1 5.0 (305) 170@4400 255@2400 TBI 3.08 ---- 2.73 ---- 89 IROC-Z
Formula
Trans Am M5,A4 LO3 V8 9.3:1 5.0 (305) 170@4400 255@2400 TBI 3.08 ---- 2.73 ---- 89 IROC-Z
Formula
Trans Am A4 LB9 V8 9.3:1 5.0 (305) 195@4000 295@2800 TPI ---- ---- 2.73 ---- 89 IROC-Z
Formula
Trans Am M5 LB9 V8 9.3:1 5.0 (305) 220@4400 290@3200 TPI 3.08 ---- ---- ---- 89 IROC-Z
Formula
Trans Am
GTA M5 LB9 V8 9.3:1 5.0 (305) 230@4600 300@3200 TPI ---- 3.45* ---- ---- 89 IROC-Z
Formula
Trans Am A4 L98 V8 9.3:1 5.7 (350) 230@4400 330@3200 TPI ---- ---- 2.77* ---- 89 IROC-Z
Formula
Trans AM
GTA A4 L98 V8 9.3:1 5.7 (350) 240@4400 345@3200 TPI ---- ---- ---- 3.27* 89 Turbo Trans Am (TTA) A4 LC2 V6 8.0:1 3.8 (231) 250@4400 340@2800 SFI ---- ---- 3.27* ---- *Borg-Warner rear axle
Camaro Specs and Photos
Our Latest Camaro Reviews! Free News, Pics, Video & More
www.InsideLine.com
2010 Chevrolet Camaro
Find our our Lowest Possible Price on the All-New 2010 Chevy Camaro!
www.CarPriceSecrets.com
Chevy Camaro Iroc
Find great deals and save! Compare products, prices & stores
www.Shopping.com
First answer by Jsloan10. Last edit by Jsloan10. Contributor trust: 69 [recommend contributor]. Question popularity: 6 [recommend question]
They could have been ordered any way you wanted. My neighbor, back in 89, wanted one real bad but his mom wouldnt but it for him cause it was too fast. So he went to JC's and ordered it with V6 wheels, no badging and nome of the fancy stuff. Then bought the wheels and decals after his mom saw it. Mind you he was almost 40 years old. They are loaded. HAHAH He then put the wheels on one month and the decals the next. They were all sitting around looking at it and ordered pizza. The pizza guy came in and said " man, thats a sweet iroc" He got busted. HAHAHAHHAHA
