Results 1 to 7 of 7
Thread: pinion seal???
    State College, PA
    3,552
    pinion seal???
    my pinion seal is leaking all over the place and my rear is starting to make some good noise probably because of the oil loss...so im gonna pull my entire 8.8, sand blast it, paint it, change gear oil and change pinion seal while its out.
    any advice on changing the pinion seal? any special tools needed or anything like that? never changed one before...
    2013 Mustang GT
    1999 Contour SVT
    4,321
    If I were you, I would take everything apart, you may have a bad bearing if it's noisy and wasn't before...
    one thing to check on, i have found at least 2 s197 cars with the diff vent clogged!! i have seen a bunch of foxes with it clogged but i never thought a new car would have it clogged.. Just be sure during final inspection before assembly that its not clogged, especially if you are getting it sand blasted..
    State College, PA
    3,552
    thanks for the tips guys....where is the diff vent located?
    2013 Mustang GT
    1999 Contour SVT
    on the pass side on top of the housing..
    i just powdercoated an 8.8 and i left the axles in it when it was sand blasted to keep the amount of sand that got inside to a minamum
    You could just put a twisted wire wheel on a grinder and clean up the housing that way. Just make sure you wear serious eye protection and be careful not to catch an edge the wrong way or it'll rip the grinder right out of your hands. When I put a wire wheel on my grinder I had to remove the guard - so be really careful how you point that thing. You won't have to worry so much about sand getting inside the housing.
    You can use a wire brush for the really tight areas where the grinder won't reach.
    This method worked really well for the rears in both of my '66 Mustangs and the rear in my Dad's '57 TBird. Once you're done hit the housing with some brake kleen a few times, wipe it down, and you're ready for paint.
    Good luck!
  1. Main Seal Replacement #1
    Last Post: 05-18-2011, 09:26 AM
  2. seal install tool
    By tylerstepp in forum Fox-SN95
    Last Post: 04-22-2011, 03:32 PM
  3. I need a sources for a seal / gasket
    By DRRummel in forum Fox-SN95
    Last Post: 06-26-2009, 12:27 PM
  4. Pinion Seal
    By no1fordgirl in forum Fox-SN95
    Last Post: 04-30-2009, 11:16 AM
  5. T5 Seal and Bearing Questions
    Last Post: 11-24-2008, 05:40 PM
