Results 1 to 11 of 11
Thread: Which Computer is this?
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I am currently running a stock 87 5.0 Hatch with an AOD. I have a few spare parts and I am trying to figure out how to use them. Please take a look at the following two links and let me know which computer this is. I am hoping this computer will help with either an AOD -> T5 conversion OR a Speed Density -> Mass Air converstion. There are no stickers on the computer case, just the computer connector.
    Thanks.
    Back: http://www.drrummel.com/Mustang/Spar...01_Cropped.jpg
    Front: http://www.drrummel.com/Mustang/Spar...02_Cropped.jpg
    Not Bad for 367 SAE RWHP Pure Stock's Avatar
    3,499
    Quote Originally Posted by DRRummel View Post
    Thanks.
    SFI-SD3
    Looks like it is a speed density version of the EEC-IV.
    2011 Mustang GT, MT-82, 3.73's :
    BONE STOCK 12.223@115.18
    Cheap SOB
    288
    Thanks for the quick reply. So the computer will not help with the Mass Air swap. Does the Speed Density computer come in Automatic and Manual transmission versions? Can the computer from a SD Auto be used after swapping to a T5, besides of talk about KOEO code errors? If so, does anyone have a link to a detailed how to process? Thanks.
    Senior Member 87notch's Avatar
    803
    http://fordfuelinjection.com/?p=17
    Looks like a speed density Lincoln Mark VII computer.
    3,499
    Does the Speed Density computer come in Automatic and Manual transmission versions? Yes.
    Can the computer from a SD Auto be used after swapping to a T5, besides of talk about KOEO code errors? When I converted MAF to SD on my 93 GT I used a computer sourced from an 5.0L auto car. (It was said that the 5-speed computers pulled some timing on the upshifts)
    Cheap SOB
    288
    Quote Originally Posted by Pure Stock View Post
    When I converted MAF to SD on my 93 ...
    WOW. Most tell me to ditch SD and go Mass Air to handle flow and cam changes. Why did you go the other way?
    3,499
    It was basically a bolt-on car @ that point with stock H/C/I. I had attained a 12 sec. timeslip with the MAF and *thought* I could go deeper into the 12's with a SD swap. The swap was performed and some street driving was all the SD combo ever would see. H/C/I swap took precedence over the mid 12 sec. goal and I haven't looked back since. It would be nice to start with a bare-bones SD coupe with the earlier pre August 8, 1988 HR cam (less aggressive cam lobe profile August 8th 1988- on) and make another run for the mid 12 sec. zone. Taking into consideration the cam revision, SD, and the svelte weight of the coupe, that would be the *ultimate* stocker.
    Banned George C's Avatar
    1,490
    you could use my notch for that goal of yours lol
    1,490
    i have a 88 harness that is for a AOD that has been converted over to MAF with the proper ECU. thta i wont be using in the future...its still in the car but can be removed if needed
    Hangin' with my toddler. Silverhatch's Avatar
    Nov 2006
    2,483
    Going to get one tomorrow. Not sure if its gonna stay or go though! Its currently short one pedal for you Joe.
    Senior Member lib88stang's Avatar
    LowHill
    2,679
    I swaped out my SD harness and ECU in my 88 and put in a 88 cali. harness and ECU and I noticed a loss in power switching to the mass air.
  1. Replies: 4
    Last Post: 01-30-2010, 12:03 AM
  2. 94-95 Computer
    By 955.0 in forum Fox-SN95
    Last Post: 05-16-2009, 10:00 AM
  3. need a computer 99 gt
    By ocracing in forum Ford Parts
    Last Post: 06-04-2008, 08:14 PM
  4. PE Computer
    By Martin0660 in forum Ford Vehicles
    Last Post: 02-20-2008, 08:59 PM
  5. Computer Help
    By RUSH2112 in forum The Bar
    Last Post: 11-21-2006, 10:58 PM
