Results 1 to 12 of 12
Thread: Smog system removal
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    Smog system removal
    Are there any write ups on smog system removal that you guys know of? What all can I remove?
    Also, what are the rules regarding emissions? If the car has less than 5000 mile/year it's exempt, right?
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    the best thing to do is to just run a short belt around the smog pump and put your stock belt on for inspections..
    Jun 2008
    Bell Acres
    469
    My buddy does the inspections, but not emissions... Plus I'm putting LT's in soon and I want to clean up the engine bay.
    Jun 2008
    Bell Acres
    469
    I understand that the tube bolted to the back of the cylinder heads gets removed, and those holes plugged. I also realize that the pump itself and the junk next to the passenger side header gets taken out. I'm going to LT's in the process so my catted H pipe will no longer have the egr tube. I'm going to reroute the belt to run without the smog pump.
    What do I do with regards to any harnesses or wire connections as well as vacuum lines. I don't want any vacuum leaks and I don't wany codes as a result.
    Castle Shannon
    1,276
    lol, check my sig ;)
    Mt Pleasant
    2,916
    Quote Originally Posted by blizzard View Post
    hey thats my line
    Jun 2008
    Bell Acres
    469
    Right but that still doesn't help with regards to harnesses/vacuum lines. I'm just starting to get into engine mods and still learning, any other area of the car I'm fine with. I have no prob ripping off the pollution control crap, but I don't want to rip shit out and end up with driveability problems.
    Huntingdon PA
    1,136
    pull out all vacuum linnes that go to any of the smog stuff you remove and cap the intake where needed. pretty simple after your done.
    709RWHP/750RWTQ
    Jun 2008
    Bell Acres
    469
    So the egr harness plug just hangs around? Doesn't it throw a code?
    Huntingdon PA
    1,136
    yup it just hangs there, and yes it throws a code. you can buy a plug to remove your EGR code... i have one laying around i'll sell to ya if you want. they're only 20 bucks new if i recall. i got mine from fordfuelinjection.com
    709RWHP/750RWTQ
    boats n hoes fork5o's Avatar
    Hopewell
    833
    everything that was said above and the harness plug need to be pushed down. ill try and get a pic up tomorrow of mine. i just put a plate straight across it to hold it down. as long as its pushed in, no codes are throw.
    i keep my under 5k a year so that its exempt. they do not run emissions, so im pretty sure the smog pump is not needed. i never had a problem with mine getting inspected. i also dont have cats.
    -Joe
    1995 5.0
    The Car
    Senior Member RAYZ02GT&93LX's Avatar
    Oct 2008
    Eighty Four
    215
    Remeber Vehicle Is Exempt If Registered In Same Name For Atleast A Year Been Driven 5000 Miles Or Less. Obd 1 Cars Must Pass A Visual Inspection. If Even In Non Im Counties. Obd 2 Cars Gets Obd2 Test And No Visual Inspection Unless In Non Im County Then Gets Visual. In Theory If Put There By The Factory It Must Be Retained.
  1. smog pump eliminator
    By bittersweetfox in forum Ford Vehicles
    Last Post: 09-06-2010, 08:15 PM
  2. smog pump help
    By 94gt5.0 in forum Fox-SN95
    Last Post: 02-22-2010, 04:58 PM
  3. smog pump removal?
    By firsttime5.0 in forum General Tech
    Last Post: 07-21-2009, 07:21 PM
  4. Need advice on emissions and smog removal
    By 95DropTop in forum General Tech
    Last Post: 04-21-2008, 08:55 AM
  5. smog delete
    By scott5 in forum Ford Vehicles
    Last Post: 03-28-2007, 09:53 PM
