Results 1 to 10 of 10
Thread: moser axles (NEW) $200.00
    moser axles (new) $200.00
    Im selling a new pair of moser axles they are hardened non tapered 28 spline and a direct replacement. They can be shortened and re-splined if you choose to narrow the rear of your car.They were $360.00 from Summit Racing. These are NEW in box, I chose to go in another direction with my car,
    __________________
    Forged internals, bored.20 over, ported and polished heads, oversized valves, centerforce clutch,full length headers, full 3" side exhaust, roots blower, intercooled, comp cams and springs, 42lb. injectors, 75mm throttle body, 90mm mass air meter, Bear brakes, front coilovers, baseline suspensions fully adj. drag launch suspension,4:10 gears ect.
    Mt Pleasant
    2,916
    guessing theyre for a 99+ car?
    yes they are.
    VA,NY
    85
    Whats the length on them from the flange to the side where the c clip goes?
    Don't get shook of a little bone stock 302 short block!!
    More Ways To Shop...
    I just coppied the page from summit racing where i bought them from.
    Moser Engineering A882805 - Moser Engineering C-Clip Axles
    large image Image is a representation of this part. Actual part may vary.
    • $359.95
    • Axles, Direct Fit, C-Clip, Rear, 1541H Steel, 28-Spline, Ford, Mustang, 8.8 in., Pair
    • Estimated Ship Date: 7/17/2009
    • Email this page
    BrandMoser EngineeringManufacturer's Part NumberA882805Part TypeAxle Shafts, Direct FitProduct LineMoser Engineering C-Clip AxlesSummit Racing Part NumberMSR-A882805Axle Splines28Axle Length (in)31.687 in./32.812 in.Axle TypeC-ClipAxle MaterialForged alloyWheel Stud Pattern5 x 4.50 in.Wheel Stud TypePress-inWheel Studs IncludedNoBearings IncludedNoSeals IncludedNoQuantitySold as a pair.NotesTone rings are not included must re-use stock or purchase new. With ABS adapter. Requires 0.615 in. knurl for the wheel studs.
    C-clip axles from the experts.
    Moser offers these forged steel C-clip street axles for car and truck rear-ends. These axles are non-tapered, with hardened bearing seats and machined C-clip grooves, to fit OEM applications. If you choose to narrow your rear-end at a later time, these axles can also be shortened and re-splined.
    Warranty
    bump
    bump
    bump
    Jun 2008
    Level Green, PA
    963
    Nevermind sorry!
    Magnaflow Magnapacks Catback
    UPR O/R X-pipe
    bump
  1. FS: 99-04 Mustang GT / V6 28 Spline Moser Axles
    Last Post: 05-05-2011, 12:54 PM
  2. New Moser 31 Spline Axles for 99-04 8.8s. Save Money!
    By 01CAMMER in forum Ford Vehicles
    Last Post: 07-11-2010, 02:17 PM
  3. Cheapest moser axles ever
    Last Post: 05-19-2010, 07:21 PM
  4. Moser, 28 spline, 5 lug FOX axles
    Last Post: 04-09-2010, 09:31 PM
  5. moser axles (new) $300.00 OBO
    By blown4_6 in forum Ford Vehicles
    Last Post: 06-15-2009, 02:44 PM
