Well, last week I was leaving a car show, the motor started banging, almost like an aluminum bat was banging on the valve cover. I towed it home. I removed the top, thinking I floated a lifter or bent a push rod maybe. I found a slightly bent push rod, so i replaced all of them including all new lifters. I changed the oil as well and as I loosened the drain, a half cup of anti freeze came out!! So I filled it up and decided to crank it up. It was banging just as bad as it did before. So after 3 long nights of hell, it went on the trailer and went to Rodehavers tonite. I'm praying its not as bad as I'm thinking. Good luck Tim!
