Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Frustrated!!
  1. #21
    plum
    487
    Well I got the motor installed and put all my top end on and relocated the battery to the trunk. While I was at it, I removed most of the wiring in the engine bay. It came time to fire it up and amazingly, it fired up and held an idle at 800rpm!! So I let it run to burn off all the paint and new stuff smell. I shut it off after 20 min and started checking everything out, and found about a cup of oil on the floor comming from the front of the bell housing. It was then that I realized that I forgot to put the rear main seal in. So off to Tims it went(towed) . Tim fixed the oil leak and spent hours trying to figure out a rocker tap. Ended up putting Scorpion rollers on and it seems to be better. The car runs better than it did before, much more power. I did put it on a diet, ac system, changed to billet accessory brackets and a bunch of other little stuff. Big thanks to Tim for all his help and a big thanks to Wick for rebuilding the tranny, I forgot what it was like to have 4th gear!!!!
  2. #22
    Junior Member
    Bellevue (pittsburgh) pa
    10
    Quote Originally Posted by 89 vert View Post
    man. glad its all working out. i bet it feels good to know you got ur whip back, and ill be dropping off my car to Tim next month. glad to see hes got a good rep with yall
  3. #23
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Pics!!
  4. #24
    No problem buddy. Glad to help out.
  5. #25
    plum
    487
    Finally got some pics with the motor installed! Here's one of the trunk as well...
  6. #26
    Jan 2009
    Masontown, Pa.
    1,618
    Wow!! Looks great!!
  7. #27
    2,483
    Quote Originally Posted by 1Badbird View Post
    Wow!! Looks great!!
    X2 Clean. Except for the FI spaghetti!
  8. #28
    plum
    487
    Yea I agree, a little more clean up to go. thanks!
  9. #29
    North Huntingdon
    1,136
    Looks sick!! What wheels you going to get? I bet Leann loves it too!!
  10. #30
    plum
    487
    She was real pissed when I started it and smoked the house out!!! Im looking at the saleen sc wheels cause I like the stagger look, 10" rear and 8" front, just gotta unload my other ones first..
    Quote Originally Posted by 89stang View Post
  11. #31
    Looks real nice Jason. Better look a little more into the 10" rear with your car being lowered. Might not fit. I know with a 10.5 it cant be lowered. Silverworm here did it on an LX.
  12. #32
    1990 lx silverworm's Avatar
    monroeville pa
    309
    not a chance of it happenin with a 315, never tried a 275 though, i had c springs on my car and had to put the stockers back in to clear the 315s. ive seen ur car jason i think its way too low for a 10 incher out back
  13. #33
    plum
    487
    Quote Originally Posted by silverworm View Post
    I have adjustable lower control arms, do you think this will work with 275 on the rear. Whats the smallest with tire you can put on a 10" wheel?
  14. #34
    never stock biminiLX's Avatar
    Beaver
    2,406
    I wouldn't go less than 285 on 10".
    You can do those wheels in 9" and it will fit better if you're lowered.
    Car looks great BTW.
  15. #35
    plum
    487
    Thanks, ill take your word for it
  1. So frustrated with electrical gremlins
    Last Post: 11-30-2008, 11:57 PM
