Results 1 to 13 of 13
Thread: Need Some Help With Datalogging
    NEWB
    Jun 2007
    Cortland, OH
    480
    Need to do some datalogging on my 02gt. Keep in mind when it comes to computers my knowledge pretty much consist of searching around the forums and buying/selling on ebay.:) I have an sct x3 tuner. I have gotten as far as downloading the sct livelink onto a laptop. I have the x3 plugged into the car and the laptop hooked to the x3. Bring up the livelink software on the laptop and try to get ecm id. At this point it keeps telling me to check my connections that it cannot communicate(i forgot the exact wording of the message). At first i did not have the key on, took care of that. It tells me to check my connection to the car, but i have already played with the datalogging in the x3 itself and it's picking up data. Am i missing something as far as configuring the x3 to the laptop so that it recognizes it? or is it something else? I did get as far in the laptop software as going thru the list and setting up the items i want to datalog.
    Thanks for the help
    Kerry
    1985 Mustang GT 3,100 original miles
    1985 Mustang Predator GT-302/Twister II 5S-0149 1 of 3
    Past Toys: 1964 Falcon Vert, 1966 Mustang(owned twice), 1978 Mustang II(first car), 1981 Cobra, 1982 Mustang GT T-Top, 1986 Mustang GT, 1986 Mustang GT Vert, 1987 Mustang GT, 1989 Mustang Notch, 2003 Mustang GT Roush Clone, 2006 Mustang V6(Stainless Works LT's, MBRP cat back, 3.73's, tb, cai), and my favorite 2002 Mustang GT MPH 302 stroker, KB 2.2, TKO 500 640rwhp/591torque.
    4,321
    Quote Originally Posted by 02pnygt View Post
    Thanks for the help
    Kerry
    If you were able to build a configuration then it should be reading your processor. Sounds silly but did you hit the start button? If you actually didn't get as far as you think, you must use a newer cable, especially with an x3. I have recently had problems with a connection cable that I used for years (x3 to laptop), swapped it out for a newer one and all was well.
    Mike
    NEWB
    Jun 2007
    Cortland, OH
    480
    Mike
    I got all the way to the point that i had the screen displaying that would show a graph and had the gauges across the top. Also showed the list of the things i wanted to log. At that point i did hit the start button.:) The cable i'm using to connect the laptop was an older cable i had laying around so i will give a new cable a try.
    Thanks for the input Mike.
    4,321
    So, when you hit the green start button, did the logging time stamp start?
    NEWB
    Jun 2007
    Cortland, OH
    480
    didn't seem to do anything that i noticed.
    NEWB
    Jun 2007
    Cortland, OH
    480
    OK, tried the correct cable that came with the x3. No luck. I wish i wasn't so lost when it comes to this computer stuff and loading new things. I'm assuming i need to download something else. When i hook up the x3 i get the message that i new device has been hooked up and that I need to load the driver(or something along those lines). I click to do that but it says something about not be able to find something or the other. I tried for the heck of it to go into the sct software, when i try to get the ecu code it just comes up telling me that it couldn't initialize to check my connection. I would have to assume this because the driver is not loaded for the handheld.
    4,321
    Unfortunately there have been a lot of issues with the x3's and some of the new software updates. The only issue I have personally had with with an older cable, bought a new one and all was well. Make sure you have the latest version of livelink and the x3lwupdater, you may need to manually load the driver...
    Mike
    NEWB
    Jun 2007
    Cortland, OH
    480
    I've been looking around on sct's website but not sure exactly what it is i need to download. Everything i'm looking at seems to be updates. I emailed sct's tech support to see if they can also lead me to what i need.
    NEWB
    Jun 2007
    Cortland, OH
    480
    Thanks for the help. Got it figured out, had to download an update. got the info i needed. only thing i didn't figure t was how to get the gauges across the top to indicate what i was reading, only had graph.
    NEWB
    Jun 2007
    Cortland, OH
    480
    got it all figured out now
    4,321
    Glad to hear!
    NEWB
    Jun 2007
    Cortland, OH
    480
    Glad to hear!
    it was one of the those deals where i was learning as i went. now that i figured it out, it is rather easy.
    4,321
    Thats usually how it works, I learn new stuff at the shop all the time
  1. Let's discuss widebands and datalogging options
    By Killercanary in forum General Tech
    Last Post: 06-15-2007, 06:07 PM
