Results 1 to 12 of 12
Thread: distributor bolt stuck?
    ok so i was going to attempt to acclerate my timing and could not get the bolt lose from the bottom of the distributor .... i tried using pb blast to no avail... is there a special tool and does any one here own it that might be willing to help me?
    I use a swivel socket on a long extension..
    State College, PA
    3,552
    go to the gym... j/k
    try a longer handle on the drive you are using for some more torque and try tapping the drive with a hammer to break it loose.
    and in all seriousness, make sure you are actually loosening it and not tightening it lol
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    i did use a swivel head into a socket with about an eight inch extension to no avail... the bolt seems to be a bit on the small side(the head isnt that thick) when i did try to take it off the socket kept on popping off. see, there isnt much room in there to actually get the swivel head on to make it all the way around. so then i sprayed some pb blast on it to try to loosen it up( little bit of rust around it)... any more ideas?
    oh and righty tighty lefty loosey on this bolt right?
    Mt Pleasant
    2,916
    try a 1/2 inch wrench?
    not long enough to get any type of hand grip on it i tried snake one in under my belt / between my hoses and still nothing...
    State College, PA
    3,552
    use a 1/2 inch socket for it, dont be using metric or you might strip the bolt.
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
    it was a half inch socket with a swivel head into about an eight inch ext then the ratchet it just wants to jump off the bolt , i cant seem to get enough down pressure on it to hold the socket down, then it also wants to catch on the distributor in certain spots of the swivel so that makes it tough too...
    Mt Pleasant, PA
    4,905
    Go to your local tool store and ask for a distributor wrench.
    awesome thanks alot!!! any idea on a price?
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by firsttime5.0 View Post
    Should be under 20.00 if I remember right.
  1. Stang stuck at work...no start
    By J-rod in forum Fox-SN95
    Last Post: 04-13-2014, 08:33 PM
  2. I guess the Throttle stuck?
    By map351 in forum Pictures & Videos
    Last Post: 06-21-2011, 05:47 PM
  3. Stuck Valve
    Last Post: 10-13-2009, 05:19 PM
  4. Got Stuck In The Mud Yesterday
    By PHFIRENO7783 in forum Pictures & Videos
    Last Post: 03-21-2008, 04:54 PM
  5. Accellerator stuck
    By 03 OW SVT in forum The Bar
    Last Post: 03-21-2007, 07:07 PM
