Results 1 to 5 of 5
Thread: 1979 four speed transmission
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    What 4 speed stick did ford use in the '79 muatangs?
    I'm trying to find a wiring diagram for a friend.
    Mark Lowry
    Wolfpack Speed, Inc.
    4290 Campbells Run Rd
    Pittsburgh, PA 15205
    (412) 279-4902
    Pretty sure it was the SROD? Someone else should confirm before you take that as gospel though.
    2005 Mustang GT
    11.2 @ 123
    single rod overdrive..
    I drive the Fairmont snailmont5oh's Avatar
    130
    They could have used one of two different transmissions. If it's an overdrive, it's a SROD (Single Rail Over Drive). They were used with V-8s and I-6s. If it's a 4 cyl, it could have the "RAN Type", which has a 1:1 fourth. You can tell visually by looking at the shifter location. The SROD has the shifter turret attached to the side of the tail housing with bolts, at the back end of a short or long tube, depending on if the shifter was located in the forward or rearward position. The "RAN" has the shifter turret cast into the tail housing, and it's centered above the tail shaft, not off to the left.
    Caledonia, Ontario
    620
    Quote Originally Posted by snailmont5oh View Post
    I do believe it is a SROD, it's a 304 V-8 from the factory.
    Thanks!
    Mark Lowry
    (412) 279-4902
  1. Replies: 13
    Last Post: 01-13-2014, 09:10 AM
  2. 1979 Mustang for $4000
    By Donstang86 in forum The Bar
    Last Post: 02-15-2012, 08:06 AM
  3. Complete 5 speed transmission package
    By orange 500 in forum Ford Vehicles
    Last Post: 05-26-2011, 07:58 PM
  4. Mustang Spec G-Force 5-Speed Transmission
    Last Post: 02-09-2010, 12:42 PM
  5. 1979 Fairmont
    By How Much? in forum General Tech
    Last Post: 11-02-2009, 11:01 PM
