thin mount under 3-inch. Or will take a reverse(pusher)mount fan.
also looking for a rubber shifter (tunnel)cover.
1969 Camaro restomod/project
1967 camaro
2011 mustang procharged
93 reef blue notch blk/int
92 calypso notch blk/int
86 t-type
1972 chevelle project
Adam, just get a set of fans from a LS1 and wire them as a pusher setup mounted on the front side of the rad. I'm in the process of doing this on my Red car now. It looks tight, but should be able to be made fit.
the 10 rib novi2000 has no room with the huge alum.rad i put in
how much was the ls1 fans?
1967 camaro
86 t-type
I got mine from Mater for like $125. They move more air than anything I have ever seen.
i think i have a taurus fan laying around if you're interested
2013 Mustang GT
1999 Contour SVT
I have a taurus fan its to thick. thanks though.
1967 camaro
86 t-type
Could try a Mark VIII fan. Depth at center is prolly around 4". Highest factory CFM fan out there. Available at alot of junkyards for around $30 or less. Do you really want a Chebby part on your Ford? Do a search on CORRAL.
I need a fan that is less than 3 inchs. thanksluxurysportscar Could try a Mark VIII fan. Depth at center is prolly around 4". Highest factory CFM fan out there. Available at alot of junkyards for around $30 or less. Do you really want a Chebby part on your Ford? Do a search on CORRAL.
1967 camaro
86 t-type
