Results 1 to 20 of 21
Thread: 94-95 Tuning Help
    94-95 Tuning Help
    Hey guys. I was wondering if it would help out my car to have it custom tuned its a 94 GT. This is a list of what I can going to upgrade or already installed.
    -All ready Installed
    2 1/2 - MAC Long Tube Headers
    2 1/2 - MAC Xpipe no Cats
    2 1/2 - Flowmaster Cat back system
    94 Cobra upper and Lower intake
    65mm Throttle Body.
    BBK Cold Air Intake
    -Still deciding on
    75mm MAF from Summit
    24LB injectors Ford Motorcraft
    The above is already installed. The 75mm MAF and 24lb injectors I am still deciding on and not sure if I should install them. Since I am not going to put on heads or a cam right now would it help it get my car tuned? I know that tunning a 94/95 is not that simple because you have to buy either Tweecer or Quarter Horse or have a chip burned in. I am still quit new to the tunning and would like to know the best way. Any help or ideas would be great
    Marc
    for those pieces you should not need a tune , maybe after heads cam and intake change but not yet save your money for other mods
    X2
    Mt Pleasant
    2,916
    no tune needed
    As was mentioned a tune isn't needed yet. Typically a tune is needed after a cam swap, or when larger injectors are used. Keep your 19's for the time being, they are more than sufficient as well as your MAF.
    Would I need to tune the computer if I put on those injectors and MAF
    With only a step up to 24's you "should" be OK, but a calibrated MAF alters the load values in the EEC so it could still cause you some issues. The best way to tune these cars for bigger injectors is to change the MAF transfer function instead of tricking the output voltage of the MAF as "calibrated" meters do to allow for larger injectors.
    So if I dont add the injectors and MAF I should be OK without a tune. I was just thinking since I got my upper intake off it would be easier to replace the injectors now. But if you think it will not make that much different I will just keep the stock MAF and 19lb injectors until I put heads on.
    Got Boost?
    West Mifflin
    1,442
    I agree. I would hold off on the injectors and MAF until you start changing heads and cam. No use in buying things twice.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Thanks guys for your input. Ill hold off buying them for now and save up for some new heads. Any certain brands I should look for or watch out for.
    It depends on what you want now, and what may be instore for the future. Without knowing that it is hard to suggest a brand/type of head for you.
    My personal choice are AFR's as I have had nothing but success with them.
    turbo'd TBone7281's Avatar
    Pittsburgh, PA (Plum)
    609
    I hope my dad is reading this thread.
    --> Tony <--
    2013 Audi S4
    You need to tell your Brother to put them on ASAP I want to see the horsepower gain he is going to have. Is the price worth the gain?
    Got Boost?
    West Mifflin
    1,442
    Trick Flow FTW
    1994 Rio Red GT
    10.60 @122.88
    Sold
    2,103
    Quote Originally Posted by car4887 View Post
    Hey I'll put em on as soon as he buys the damn things. And from what I can tell, yes, they are worth the $ you spend on them.
    03 Cobra=slow show car...
    13 F-150 Limited
    afr or TF you cant go wrong with either, both proven heads... Post some pics up of that 95.. I love me some 95s
    Member 94opalgt's Avatar
    Nov 2007
    akron
    47
    Quote Originally Posted by Rio94gt View Post
    Trick Flow FTW
    first set of trick flows i bought ended up with 8 crooked intake valve seats.
    if you buy them, have em checked before you put em on the car.
    i say AFR. i shoulda bought what i wanted in the first place, but i settled for trickflow. and that's what i got. never again.
    Current Car:
    1985 GT
    Past Cars:
    94opalgt 300rwhp 336rwtq-Gone
    94 GT vert, 309rwhp 326rwtq-Gone
    82 T-Top GT-Gone
    Got Boost?
    West Mifflin
    1,442
    Were yours right out of the box?
    Never heard any thing like that about Trick Flow.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Nov 2007
    akron
    47
    right out of the box. they were going to fix them for free but i had them ported and the dude that ported them ported into the valve seats, so they couldn't.
    what they did was sell me a set they had on an engine dyno for 3 hours for $750. not to bad.
    but think about this, now there is a out of the box set of heads on my car that i basically spent $2300 on. $1300 new, $300 to port them, $750 for a new set. they would have ported those for me for another $400, but i didn't have the cash.
    i will say this, they will make right if anything is wrong with there stuff. it just rubbed me the wrong way that they were f'd up brand new, ya know?
    sorry for the highjack.
    Current Car:
    1985 GT
    Past Cars:
    82 T-Top GT-Gone
    609
    You're out of the loop.
    Edit: You also need a new sig.
    --> Tony <--
    2013 Audi S4
  1. Tuning...
    By 92306gt in forum SN95-New Edge
    Last Post: 07-08-2010, 08:10 PM
  2. Tuning
    By 08stangftw in forum Fox-SN95
    Last Post: 07-27-2009, 10:34 AM
  3. 94-95 tuning?
    By 95gts in forum Fox-SN95
    Last Post: 01-08-2009, 06:43 PM
  4. Tuning?
    Last Post: 07-09-2008, 11:00 PM
  5. Tuning
    Last Post: 04-28-2007, 08:09 AM
