Results 1 to 11 of 11
Thread: Front coil overs
    Gibsonia
    772
    Front coil overs
    I am looking to put a tubular k-member and coilovers on the front of my 91 mustang. Was wondering if anyone has done this, and how wide of a wheel/tire you can run in the front. I think the coilover spring is going to hurt tire clearanace. I have a 17x9 with a 245-45-17 on the front now with stock suspension. Thanks
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Mt Pleasant, PA
    4,905
    You have to run a shorter spring with wider tires. Its been a while but you need to run either a 10" or 12" coilover spring.
    Gibsonia
    772
    That makes sense to me now. Thanks for the info
    My collection:
    01 cobra in pieces
    02 dodge cummins
    I have custom made 17X9 bogarts up front with a PA Racing tubular K member, strange coil-overs and adjustable struts, and 175 14" Qa1 springs. My wheels rub, but I have since bolted on a set of 17X8" wheels and they clear. I plan to send my wheels back to bogart to have them cut down to 17X8, luckily when i had them built they offset is different than stock so that when I have these cut to a 17X8, I will have less back spacing than the stock 17X8's therefore I'll have even more clearance.
    Thanks for the tip Lou, I never heard nor thought of that. Maybe I'll switch springs instead of having the wheels cut down as it'll save me a ton of money.
    Mt Pleasant, PA
    4,905
    No problem, the only disadvantage I could possibly see with the shorter springs is less stored energy for launch purposes.
    Gibsonia
    772
    What about ride quality with shorter springs?
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Mt Pleasant, PA
    4,905
    Most street kits have a 12" spring and aren't too bad depending on the rate you choose. Im pretty sure that its a 10" spring that is used with wide tires now that I think about it. Those im no help with info on ride quality, its been a few years since I sold a 10" kit.
    Quote Originally Posted by fast4ord View Post
    Gibsonia
    772
    You still sell the springs? I might end up using a 17x8 wheel as well, which might work better. Thanks for all the help.
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Mt Pleasant, PA
    4,905
    Yes, I don't stock them but I could order them in.
    i'm running 17x8 and 175 lb 12 inch springs with no clearance issues
    Mt Pleasant, PA
    4,905
    Good info Troy!!! Maybe its just the 10 inch wheels or different offsets?
  1. WTB coil overs or front drag struts
    Last Post: 01-24-2015, 01:14 AM
  2. Replies: 1
    Last Post: 03-14-2014, 11:42 PM
  3. coil overs
    By 92notch in forum Ford Vehicles
    Last Post: 02-10-2012, 08:58 PM
  4. 14-130# coil overs
    Last Post: 06-28-2010, 09:13 PM
  5. wtb drag struts and coil overs
    By badstanglx in forum Ford Parts
    Last Post: 08-25-2009, 07:09 PM
