Results 1 to 3 of 3
Thread: 352 a4 block, novi 2k,csu carb, afr's lots of go fast stuff
    NEWB
    altoona,p.a
    299
    352 a4 block ---- 3500.00
    diamond 8.5.1 pistons .060
    eagle 4340 forged crank 3.4
    eagle 4340 forged h beams 5.4
    stainless o ringed
    arp 1/2 head studs
    afm b451 cam
    ford racing hyd lifters
    cloyes 9 way adj timing set
    moroso 7qt pan pickup/dipstick etc
    hpm motor mounts
    scat sfi 157th flexplate
    romac sfi balancer
    arp hardware in the lower end
    m68hv oil pump
    ford racing h.d oil pump shaft
    8000 miles runs great, going back to an all aluminum 400+ nitrous motor
    will only ship if i only have to crate it and drop it off otherwise pickup local
    vic jr 302 intake -- 150.00 shipped
    afr 205 heads 58cc w/ afm springs/retainers/keepers 1400.00 w/ pushrods shipped
    crane 1.6.1 7/16th rocker arms -- 125.00 shipped
    crane hi6 dsr ignition trc and map sensor included -- 225.00 shipped
    msd blaster 2 efi coil -- 25.00 shipped
    msd billet mech dist 302 for vic jr intake -- 150.00 shipped
    kooks 1 7/8 (8.2 deck) 3.5 collector 3inch wide pattern fit canfield/afr 205 and im sure others -- 400.00 shipped these are bolt on headers that do not require adapters
    2 5/8 autometer super comp 30/30 vac/boost gauge 30.00 shipped
    2 5/8 silver comp fuel press gauge 10-100 psi 30.00 shipped
    csu 750 blow thru carb w/ brpv 1 month old --- 750.00 shipped
    e.v o ringed bonnet ( with divider allready ground out ) -- 150.00 shipped
    renegade(drivers side) novi 2000 -- 2200.00 shipped
    8 inch crank pulley
    3 inch blower pulley
    dual tensioners
    new belt
    piping for blow thru carb or efi (have both)
    mondo bov
    vortech cog pulley kit w/ hpm blower brace -- 175.00 shipped
    73 lower
    30 upper
    tensioner
    belt
    this stuff is new never used
    pro-m 83mm mass air meter for s/c and 75lb injectors --- 125.00 shipped
    please call 814-207-3299 or email ruthlessgsx@aol.com for questions , most of the stuff is in the car still but i can still get pics of most of it, you can also here it run over phone or in person.. i will be taking it apart asap. thanks
    "biggb"
    Aug 2008
    duquesne
    544
    pics available for msd mech. distributor??
    -greco
    92 Coupe, 10.72@133
    NEWB
    altoona,p.a
    299
    yea whats your email address , thanks
    "biggb"
  1. novi 2000, fluidyne , pa s.c c4 , lots of stuff
    Last Post: 08-19-2009, 09:53 PM
  2. 1993 9 sec car roller + lots of go fast stuff
    Last Post: 08-14-2009, 10:46 AM
  3. Replies: 3
    Last Post: 07-26-2009, 08:29 PM
  4. 352 a4 block/kooks/canfield/etc go fast goodies
    Last Post: 02-23-2008, 05:49 PM
