Results 1 to 5 of 5
Thread: 1999 Ford Mustang Cobra
Hybrid View
    Curious if there's any interest in my 99 Cobra. It has a host of chassis/suspension/braking mods and can be sold either fully modded and ready to go, or demodded for less. Mileage is 69k. I just completely rebuilt the rear last summer with brand new EVERYTHING, except the Torsen T2R...there was nothing wrong with it. :)
    MM coilovers all 4 corners with other MM stuff, 00R Brembo's, bushing'd IRS, exhaust, short throw, OEM 00R wheels, Recaro Pole Positions with Willans 5-point belts, Autopower 4-point bar, previously mentioned Torsen, cooling upgrades...yadda yadda yadda. I have the full parts list on my work computer but I believe as the car sits it has $14k in parts alone.
    Price for the car as it sits would be $14k.
    I can de-mod and install OEM 03/04 springs and bilsteins, factory leather seats, factory brakes, OEM catback.
    Price for the car de-modded would be $11.5k
    Car is black exterior and parchment interior.
    1999 SVT COBRA For Sale
    ________________________________________
    Black ext, Parchment Int, 5 speed, A/c, tilt, Mach 460, pw, pl, pm, 69,000 miles.
    The list of goodies with approx prices:
    Interior:
    1500 Recaro Pole Position seats
    400 Willans 5 point "street" harnesses (2" wide)
    450 Autopower 4 point Road Race bar, textured and color matched to the interior
    250 A pillar 3 gauge pod w/ Autometer Oil Temp, Trans temp (diff), and Oil Pressure gauges
    150 MMR rear seat delete kit
    Exterior:
    Stock, with 01 replacement "Cobra" rear bumper, fixed under the old warpage TSB
    Stock 99 wing moved back about 3/4"
    MGW Black anodized gas cap
    Wheels/tires:
    800 (4) 2000 Cobra R 18" OEM factory wheels w/ Michelin Pilot Sports and Dunlops
    Suspension:
    Front-
    200 MM caster/camber plates
    40 MM urethane control arm bushings
    150 Baer bumpsteer kit
    100 MM K member brace
    100 MM strut tower brace
    160 MM valved Bilstien Race struts
    540 MM coilover kit w/ 425# springs
    1250 Saleen Brembo front brakes w/ HPS street pads and Hawk performance pads
    200 2000 R carbon fiber brake ducts and 3" brake hose run from front bumper
    *Car has brand new hubs on both sides with about 1000 miles on them.
    Rear-
    150 MM full length subframes
    300 Custom welded rear shock brace (setup to tie a full cage in, which at one time was the plan)
    670 MM 2000R rear shocks
    420 MM rear coilover kit with 650# springs
    80 MM urethane control arm bushings
    150 Bruce and Ken's aluminum front diff bushings, rear Delrin diff bushing
    50 MM urethane IRS subframe bushings
    200 Kenny Brown modified IRS cradle
    *Brand near rear rotors and street pads
    Driveline:
    Engine:
    250 03/04 Cobra radiator
    65 Custom 170 deg high flow T-stat
    200 WMS cold air kit
    100 Pro-M mass air (with WMS kit)
    400 Superchip tuned
    300 Romac billet steel balancer, SFI certified
    50 Alternator has the Steeda underdrive pulley
    Battery (optima red top) located in trunk
    100 External Engine Oil cooler
    "Fix" performed March 2000, extrude hone lower intake, not the other one
    Transmission:
    400 Spec aluminum flywheel
    450 McCleod Stage II clutch, 11"
    150 Steeda shifter
    400 Griggs aluminum driveshaft
    100 Steeda Quick Release quadrant and firewall adjuster
    Differential – I just completely (all brgs, seals, etc) rebuilt this about 3k miles ago:
    475 Torsen T2R 28 spline
    175 FMS 4.10 gears
    400 Custom (or fabbed, however you choose to word it) diff cooler:
    -Modine pump, Modine cooler, Aeroquip lines, t-stat controlled - works awesome
    Exhaust:
    250 Bassani stainless off road X pipe
    450 Magnaflow stainless cat back
    and an additional fabbed side exhaust with single chamber flowmasters.
    Total Estimate in parts alone: $12,075
    A few pictures.....
    bumpage
  1. Replies: 1
    Last Post: 04-22-2013, 08:02 PM
  2. FS: 1999 Ford F150 4x4
    By juice_man_86 in forum Ford Vehicles
    Last Post: 04-26-2012, 02:58 PM
  3. FS/FT: 1999 Mustang Cobra, Eaton Swapped, Rio Red, 51k Miles
    By svtfever2011 in forum Ford Vehicles
    Last Post: 07-10-2011, 08:55 PM
  4. FS 1999 Ford Escort ZX2
    By 95V6 in forum Ford Vehicles
    Last Post: 08-26-2010, 11:36 PM
  5. 1999 Polished Mustang Cobra Wheels
    By cstunkard in forum Ford Vehicles
    Last Post: 05-01-2009, 11:23 AM
