Since it is fundamental that efficient lubrication systems help keep the crankshaft free of unwanted oil, the use of this special windage tray kit is necessary for maximum horsepower.
This style windage tray is designed to quickly disperse oil leaving the connecting rods and main bearing areas so the large drops of oil do not bounce off the interior of the oil pan back into the spinning crankshaft.
The tray is made of lightweight 18 guage steel and features a built in adjustable scraper, using a precision contour to create the correct scavenging effect, while improving oil drainback.
Our heat treated grade 8 extended main cap bolts and nuts are supplied in the kit making this a totally bolt on windage tray with NO other modifications required!
MPG=89.95
Bolt on 12 horsepower retaining the stock pan;)
$75.00 shipped
