Results 1 to 14 of 14
Thread: Need answer ASAP, do axle bearings need packed with grease?
    I'm in the middle of installing new axle bearings and seals on my cobra and I don't know if I should pack the bearings with grease or if they are only to be lubricated via the rear end fluid. If anyone can answer this ASAP I'd appreciate it. I've been searching the net and haven't found and answer yet. My bearings do not appear to have any sort of grease in them.
    Super Moderator u1arunit's Avatar
    3,356
    Paul it says how to do the install here. Looks like no grease is necessary.
    http://books.google.com/books?id=pLR...cement&f=false
    Mark
    LeMans Blue Z06
    Thanks Mark, I never used the google books search option before. I'll have to remember that. I looked up another link there and it too says to just put rear end fluid on it so that is what I'm going to do... I just hope I have a socket here big enough to use to knock the new bearings and seals in.
    3,356
    No problem, glad to help.
    Mark
    LeMans Blue Z06
    Thanks again Mark... this job is done! :)
    Now to install my carbon fiber clutch pack rebuild kit....
    Sounds like i'm late, but no grease, they are lubed by the rear end fluid. That is why C-clip eliminators leak ;)
    I just installed a set of bearings / seals in mine tonight. Just waiting for the new axles to come.
    Thanks for the reassurance Bob! I got the bearings and seals in, and managed to get the S spring, spider gears, and clutch packs out. My carbon fiber clutch pack should arrive tomorrow along with the ABS sensors that had to be broken in order to be removed. That sucked as they are $140 to replace. :( My new panhard bar should be here in a few days as well and then I'll be road worthy again! :)
    Castle Shannon
    1,276
    i have some abs sensors laying around ;)
    Not if a modified seal is installed into axle tube. http://www.modularrevolutiontech.com/C_clip.htm
    You got me ;)
    I was in general trying to "prove" there was gear lube out there and no need for grease. Not all C Clip eliminators leak (until you drive them :D). That is a nifty little fix for the issue. Kind of a home brew version of this ...
    http://www.sealsit.com/axlehub.asp
    Ok guys, I'm having some trouble. I can not get the damn S spring in. I tried collapsing it on one side with vice grips and then a C clamp but its not even close to going in. Any tips/advise? I need to get this together ASAP. Thanks in advance!
    3,356
    Paul did you try to pull the axles out and/or turn them a little on each end while inserting it? You are trying to fit it thru the service opening correct?
    Mark
    LeMans Blue Z06
    Paul - some magical combination of vice grips, screw drivers, hammers, and cussing. I have made 4 or 5 attempts and had it fly out, bite my fingers, then magincally slide in without really changing anything. I geuss I am no help other than it needs patience :D
    One more thought Paul - you mentioned a t'lok kit earlier. Have you had it together, axles in and cross in installed before trying to get the spring in?? If you have the side gears shimmed too tight, it won;t go together at the next step anyway, and would make the spring even tougher.
    I would hate to see you get it in there only to have to pull it out to change shims (BTDT)
  1. Grease Monkey in CBG
    By 95V6 in forum The Bar
    Last Post: 12-02-2011, 11:36 PM
  2. can anyone answer this
    By bill412 in forum SN95-New Edge
    Last Post: 01-10-2009, 09:22 PM
  3. amazing what a bit of elbow grease can do
    By MBH in forum Pictures & Videos
    Last Post: 10-18-2008, 12:00 AM
  4. 3" over axle tailpipes & under axle anti-roll
    By 04snake in forum Pictures & Videos
    Last Post: 05-03-2007, 12:11 PM
  5. anyone know the answer to this ?
    By INSANELY CRAZY in forum The Bar
    Last Post: 02-13-2007, 06:21 PM
