Thread: Where can I get heads milled in the south hills?
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    I want to have my heads decked before they go on the car...
    Should it be 10 thousandths? How much will this affect compression/will it slightly boost power?
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    Be prepared to check pushrod geometry and perhaps buy new pushrods if you are running E7's which are pedestal mount. For the small increase it'd net versus the money it'd end up costing, I'd leave them alone unless they absolutely need it.
    Jun 2008
    Bell Acres
    469
    What are the chances that the heads won't seat right? I'm not interested in performance rather a good seal.
    I've got brand new Comp Cams 1.6 rockers and pushrods as well as Trickflow lifters, btw.
    Quote Originally Posted by Tony71502 View Post
    It all depends if they are warped or not. Its not a bad idea to check them, however if they need milled your new pushrods may not work. Pushrods are always the last thing to buy when assembling an engine as you can not determine their length until everything is together. Deck height, gasket thickness, cam base circle, lifters, etc all have an effect on pushrod length. You may get lucky and be OK with what you have, but if you don't check it you are asking for trouble. Check the swept area on top of the valve and the location of the roller tip on the valve. The roller tip should be centered or slightly to the intake side of the valve at zero lash and the swept area should be kept to a minimum on the valve tip face. Check this with a light amount of grease on the valve tip, setup the rocker assembly gently, and then rotate the engine until the valve opens and closes fully. Pull the rocker off and look at the top of the valve to see where your swept area is and how much travel it has across the valve tip. Also, with stock pedestal mount heads make sure once the lifter is on the cam base circle and you reach zero lash that your torque wrench clicks off between 1/2 to 3/4 of a turn when set to around 20ftlbs of torque. If it clicks off earlier your pushrods are too short, if it takes more than 3/4 of a turn your pushrods are too long. There are shims available to raise the rocker pedestal off of the head which can help with small adjustments if the rockers are too long, but they are for "fine tuning" only. If the rods are too short you will be buying new pushrods without a doubt. Typically milling of the head will make the pushrods too long, and the shims may be all you need depending on how much needs removed.
    I would suggest Brockers on 51 by Century III Mall. Don't know if I spelled that right or not.
    State College, PA
    3,552
    x2 on them. they do great work and have a good reputation. i think its spelled broughers
    2013 Mustang GT
    1987 Mustang GT
    1999 Contour SVT
  1. WTB Tires in the South Hills area...
    By SteelTownStang in forum Ford Parts
    Last Post: 08-16-2012, 02:54 PM
  2. Hello from the South Hills
    By DriveWFO in forum Welcome New Members
    Last Post: 08-31-2011, 12:40 AM
  3. Painter/South Hills
    By SteelTownStang in forum General Tech
    Last Post: 06-22-2010, 06:56 PM
  4. New Guy From the South Hills
    By fmfkid250 in forum Welcome New Members
    Last Post: 12-09-2008, 12:12 PM
  5. New cobra owner in the south hills
    By MBH in forum Welcome New Members
    Last Post: 03-17-2008, 10:07 AM
