Results 1 to 11 of 11
Thread: maf to carbed car. how can it be done?
    up and running
    Jun 2009
    south hills
    418
    im tired of the efi and the damn computer fighting me all the time so i decided to go to carburator set up. what do i need to do and change in order to change my efi motor into carbed. any help?
    Chevelle Owner Tony71502's Avatar
    Jun 2008
    Bell Acres
    469
    I'm not sure, but my buddy would be interested in your MAF wiring and if you are swapping the computer, that too. If you want to sell it.
    1991 Jewel Green Ford Mustang LX ~ 5.0L / 5-Speed
    2011 Torch Red Ford Ranger ~ 2.3L / 5-Speed
    1971 White Chevrolet Chevelle Malibu w/ Blue Stripes ~ 8.2L(502) / 4-Speed
    you will need to change out the fuel pump, its better to get a carbed fuel tank and mount a holley pump back by the tank, you wil have to get an intake, carb, msd dizzy/box..
    i just watched an episode of two guys garage(i think that what it was) and they did a thing where they took a efi ls1 and converted it to a carb set up. they dynoed the thing and just by the conversion it upd the hp by like 50-60 then with a bit more tuning they had it up over 100 hp... kinda cool actually!
    408 Fox Chance Sumney's Avatar
    Jul 2008
    Washington, Pa
    3
    Use the stock fuel pumps and lines just have to run a bypass regulator around 6 psi. you can find a fitting that will screw in to the regulator then flare the factory lines keep the coolant temp wire and oil pressure wire you can trace them clear to the main harness connector and the wiring for the alternator and can the rest. Run a msd box or mallory
    In the process of putting together a 408w backed by a tko 600 and a 456 gear.
    up and running
    Jun 2009
    south hills
    418
    what about the stock computer. i know i will have to do something to that.
    Senior Member scott5's Avatar
    NC
    10,168
    Quote Originally Posted by Gray 5.0 View Post
    yea get rid of it
    NC
    10,168
    Quote Originally Posted by firsttime5.0 View Post
    it was horsepower... I watched that too.. dam them ls1s
    up and running
    Jun 2009
    south hills
    418
    can i just take it out and go from there or do i have to do other things to it
    You can throw the MDS Distributor over a hill the day you open the package up. Right along with the box. Everybody should know what MSD stands for by now..
    My
    Spark
    Dissapeared!!!!!!!!!!!!!!!!!!
    TELL IT LIKE IT IS crazylou's Avatar
    Nov 2008
    ELIZABETH TWP.
    885
    Yeah Now Ur Talkin Big Ol Dinosaur Pumper All The Way... (alot Easier) Just Think U Can Tune It Urself Once U Get The Hang Of It ...look At My Sig And Thats A Start Up And Drive Everyday Hyd Roller If I Want 2...
    COREY...
    *04 Torch Red Cobra
    1 of 164 with med.graphite inserts
    Work done and Tuned by Rodeheaver's Hot Rod shop...
    471hp/489tq
    *1970 chevelle ss L-S5 454, 4 spd
    real deal not a clone have paperwork
  1. throttle cable bracket for a carbed 302
    By Ckelly91lx5.0 in forum Fox-SN95
    Last Post: 04-19-2012, 05:39 PM
  2. Carbed 2v All Motor
    By Ares in forum Pictures & Videos
    Last Post: 03-29-2009, 11:01 PM
  3. 5.0 carbed to EFI swap?
    By slimvdub in forum Fox-SN95
    Last Post: 02-15-2009, 10:45 PM
  4. Older carbed 5.0 vacuum lines?
    By jclose11 in forum Fox-SN95
    Last Post: 10-21-2008, 10:28 PM
  5. Fuel Pump for carbed motor
    By PSUmustangGT in forum Ford Parts
    Last Post: 07-12-2007, 10:59 PM
