Results 1 to 5 of 5
Thread: Auto to stick
    Auto to stick
    What all does it take to switch an auto to a stick in the sn95 cars? Its already a v8.. Has an auto in it, and im wanting to put a tko in it. I know i need the tranny, pedals, crossmember maybe, clutch and all the stuff.. is the tranny harness seperated from the rest of the computer harness on a sn95?
    Jan 2008
    Jefferson
    4,674
    Yes the tranny harness is separate from the main. But you can use the auto harness. You can modify it too work with reverse lights etc. If you do it I can help you through it.
    I found a few threads over on a diff site that spelled it out for me... Hopefully the guy will still have the car next weekend..
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I just did this same swap on my 95. I am having difficulty with the auto harness adapting it to make the reverse lights work. could you post a link with what you found? BTW, it is a fairly simple swap, just make sure you use a clutch fork from a Fox and a 5/8" driveshaft spacer if you are re-using the auto driveshaft.
    pm sent
  1. FS: Reebok 8K Sr. Hockey Stick
    By Terminated in forum For Sale
    Last Post: 08-30-2012, 11:36 AM
  2. auto vs stick
    By yeahloh95 in forum Drag Racing
    Last Post: 05-24-2012, 06:20 PM
  3. Stick Shift Carange
    Last Post: 06-06-2011, 05:51 PM
  4. dip stick problems
    By fryer19 in forum General Tech
    Last Post: 05-15-2010, 08:56 AM
  5. Stick A Fork In The Sens!!
    By TJH64 in forum The Bar
    Last Post: 04-15-2008, 08:21 PM
