Results 1 to 10 of 10
Thread: Wanted: MAF to air filter adapter
Hybrid View
    Sep 2007
    Dayton PA
    3,795
    I need the 4 bolt adapter that bolts to the MAF like the one shown in this kit....
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Gibsonia, PA
    323
    I have one from a Vortech kit that mounts up in the fender well of a 94/95 car. It gets you lots more room. Not sure if it will work on the 93 car.
    Gibsonia, PA
    323
    Quote Originally Posted by 95DropTop View Post
    Like this one:
    that will work, just cut off the bracket, or you may be able to use it..
    Sep 2007
    Dayton PA
    3,795
    Thats it, i want to go back to 19# injectors and im planning on using a Mark VIII MAF
    what do you want for it?
    01 cobra: traded
    Gibsonia, PA
    323
    10.00 + around $5.00 if you want me to ship it to you. I think the cost is $4.40 UPS ground. So $15 will cover it if shipped. Or, of course, you can pick it up.
    Let me know if you want it.
    Thanks, Vince.
    Gibsonia, PA
    323
    Ok, I dug the bracket up this AM and now realize that it is a slight bit different than the stock pic that I sent you.
    Here is an actual photo.
    This one mounts in the fender on a slightly different bracket and has a bung for the Air Temp Sensor in it. You may already have a provision for the Air Temp Sensor in your CAI or elsewhere.
    Like I said, if you want to mount this thing in your fender and get the MAF and filter tucked away in there, it is a great solution. If you are going to put the stuff where it normally goes, then this may not be for you.
    Let me know if you still want it and I will send it to you today.
    Sep 2007
    Dayton PA
    3,795
    hmm im not sure that will work for me.......i think it needs to be pretty shallow in the hole im going to put it in, i want to connect the mark 8 MAF to my stock air box with the factory connector
    01 cobra: traded
    Gibsonia, PA
    323
    Yeah, sorry. I didn't have it with me and forgot that it had that built-in bung. Good luck finding what you need!
    Sep 2007
    Dayton PA
    3,795
    thanks for the response and pics!
    I may try to get it off you if i dont come up with anything
    01 cobra: traded
  1. K&N air filter for 99-04 GT mustang
    By Chargin2004GT in forum Ford Vehicles
    Last Post: 02-20-2013, 09:12 PM
  2. pmas 80mm maf w/filter
    Last Post: 01-26-2009, 08:31 AM
  3. Pmas 80mm Maf with filter low miles
    By John4cam in forum Ford Vehicles
    Last Post: 07-16-2008, 10:31 PM
  4. Changing the Cabin Air filter
    By 06stanggt in forum General Tech
    Last Post: 09-17-2007, 12:53 PM
  5. For Sale: 42# Injectors and 80mm Pro-M MAF w/ Filter
    Last Post: 01-12-2007, 01:13 PM
