Results 1 to 6 of 6
Thread: 1993 9 sec car roller + lots of go fast stuff
    NEWB
    altoona,p.a
    299
    first with cash gets the stuff..
    1993 lx coupe orig 5.0/5spd "ROLLER"
    converted to carb, could easily put back to efi.
    red with mostly black and some gray interior
    85k orig miles /orig paint/body clean and clear title never in any accidents whatsoever
    5 lug converted
    upr tubular k member
    upr tubular a arms
    upr coil over's
    eibach springs
    upr caster/camber plates
    lakewood 90/10 50/50 shocks and struts
    upr dbl adjustable solid pro upper and lower control arms
    upr spherical housing bushings
    upr anit roll bar
    wild rides upper/lower battle boxes welded in
    8 point cage w/ drivers side swing out door bar welded in to frame were applicable
    lakewood driveshaft loop
    subframe connectors welded in
    33 spline moser axles
    33 spline moser spool "light"
    c clip elim's
    tfs rear girdle
    3.73 motorsport gears
    long studs
    aeromotive a1000 pump&filter
    -10an feed
    -8an return
    13204 fuel regulator
    -6an lines for carb ( entire fuel system is there )
    glenns sumped tank
    recaro race seats
    drivers side 5 pnt harness
    custom carpeted rear seat delete
    cervini 4 inch hood bolt on
    cowl gauge concepts pod for on the cowl
    2 5/8 fuel press gauge
    2 5/8 oil press
    2 5/8 water temp
    2 5/8 trans temp
    weld pro star 15x10 and 15 x3.5
    skinny tires
    325/50/15 bfg drag radials 70% tread
    manual brake setup
    15%tinted windows
    moroso rear mount battery pan
    moroso cut off switch
    rear seats were deleted, car is inspected per pa and was a street car, all lights,signals,wipers,power windows, and such work as factory. ran a best of 5.82@121 with a 1.32 60ft the car works great, leaves straight, very minor dings, a few rust bubbles on rear deck lid by key hole, hood is primered , the overall paint is great and very shiny, 8/10 overall condition for being original. center console was removed and i customized it. im getting out of the game for awhile and do not want to look at the car sitting there in my garage. the car with a 410 windsor block weighed roughly 2700 w/o driver
    5000.00 obo i need to move it cash talks
    call 814-207-3299 or email ruthlessgsx@aol.com for pics ..
    also have lots of other parts for sale..
    kooks 1 7/8 x3.5 (8.2) deck -- 300.00 shipped
    fluidyne aluminum radiator -- 200.00 shipped
    csr (blue) electric water pump w/ march alternator brackets, and pulleys --- 300.00 shipped
    romac 28oz sfi balancer --- 100.00 shipped
    scat 28 oz sfi flex 157 th -- 50.00 shipped
    eagle 4340 3.4 stroke crank forged, needs welded up and cut( easy fix not to bad) --- 150.00 shipped
    eagle h beam forged rods (perfect shape)---250.00 shipped
    diamond .060 -22cc dished pistons .927 pin 8.2 deck 8.5.1 w/58cc heads(perfect shape) -- 250.00 shipped
    ford a4 race block, 1 cyl needs sleeved and re bored, it was .004-.006 out the rest are perfect at .060 -- 400.00 (pick up only)
    arp 1/2 head studs-- 50.00 shipped
    moroso 7qt oil pan (pick up/dipstick inc) -- 150.00 shipped
    would make a package deal for the whole shortblock, was going to cost me 600-700 to put it back together. would sell from balancer to pan as listed for 1200.00 picked up , could have a 352 cid race motor fresh for 2000 or less ...
    victor jr 302 carb intake --- 125.00 shipped
    msd pro billet 302 distributor (mech advance) --- 150.00 shipped
    jw 157 th zero balance flex for c4 -- 50.00 shipped
    hpm solid motor mounts -- 50.00 shipped
    ford motorsport tall polished valve covers --- 75.00 shipped
    ford racing hyd roller lifters,spiders,dog bones -- 50.00 shipped
    cloyes billet timing chain set 9 way adjustable (barely used) --- 25.00 shipped
    msd blaster 2 tfi coil --- 25.00 shipped
    m/t 28x10.50x15 slicks (65-70% tread) --- 150.00 picked up
    pro m 83mm s/c meter for 75lb inj -- 125.00 shipped
    paxton novi 2000 drivers side renegade blower setup -- 2000.00 shipped
    7inch aluminum asp crank pulley
    3.00 blower pulley
    dual tensioners
    gates belt
    mondo polished bov
    piping for a blow thru carb or i got the piping that was used for efi ( i converted to carb)
    would take trades on 87-93 gt's 5 speed in good condition,(paint must be nice) close to stock, no major mods or ls1 cars, again close to stock.. would even put some cash up for the right deal..
    number is up above, throw me some offers guys, i want to move stuff.. however dont be stupid with them either. thanks
    p.s willing to deliver the roller within 2 hours of 16601, 500.00 non refund deposit prior... lots have seen the car and parts and can vouch for there condition.. also have a few you tube vids off the car as well, nothing has changed since then except the pro stars are on it now , and offcourse no motor or tranny .lol
    [ame="http://www.youtube.com/watch?v=BRQtvYuOGF0"]YouTube- Ford Mustang stroker,331,347,393,408,410,NOS,Turbo,Burnout[/ame]
    http://www.youtube.com/watch?v=5mQhIg38FK4&eurl=http://www.youtube.com/user/Sportwerks408
    "biggb"
    Good seller
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    NEWB
    altoona,p.a
    299
    roller is sold.. thanks
    "biggb"
    Member bspilner's Avatar
    Jun 2007
    Fox Chapel
    63
    Pt# for distibutor?
    5 lug converted
    upr tubular a arms
    upr coil over's
    eibach springs
    upr anit roll bar
    c clip elim's
    tfs rear girdle
    long studs
    -10an feed
    -8an return
    glenns sumped tank
    recaro race seats
    2 5/8 oil press
    2 5/8 water temp
    2 5/8 trans temp
    skinny tires
    manual brake setup
    15%tinted windows
    3.00 blower pulley
    dual tensioners
    gates belt
    mondo polished bov
    http://www.youtube.com/watch?v=5mQhIg38FK4&eurl=http://www.youtube.com/user/Sportwerks408[/quote]
    Pics of the valve covers to edsviper@gmail.com.
    dist. was sold to blacksunshine.....
    1967 camaro
    86 t-type
  1. Replies: 3
    Last Post: 11-09-2010, 05:15 PM
  2. 88 Notch AZ/CA car Lots of go fast parts
    By wht88cpe in forum Ford Vehicles
    Last Post: 08-09-2010, 11:07 AM
  3. Replies: 2
    Last Post: 07-31-2009, 01:44 AM
  4. lots of go fast goodies
    Last Post: 09-02-2008, 09:23 PM
  5. 1991 notch roller and go fast stuff
    Last Post: 06-23-2007, 12:42 PM
