Results 1 to 6 of 6
Thread: stall problem
    stall problem
    so i just added a bbk 75mm throttle body and a bbk cai, now every so often the car stalls out. i think its running lean, how can i fix his problem??? (01 gt 4.6 motor)
    thanks in advance,
    -Mike
    Mars, PA
    1,696
    I had both on my old 01 and never had an issue. I would check for vacuum leaks first and then see if your idle air control valve is on all the way. More than likely its just one of the hoses on your intake tube is not on all the way.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    sometimes you may have to clear the keep alive memory when swapping out idle related parts, just take off your pos battery terminal and hit the brakes a few times to drain any voltage out of the system and then hook the batt cables back up and see how it does..
    4,321
    Quote Originally Posted by Chosen Moto View Post
    thanks in advance,
    -Mike
    It could be several different things causing your issue but the first place to start is BBK. They make some of the worse aftermarket performance products for the Ford Mustangs, you get what you pay for! Check for the obvious to include your TB blade set screw and TPS voltage...
    Good luck either way!
    Mike
    Gibsonia, PA
    323
    thanks in advance,
    -Mike
    What year is your car? Did the BBK come with a big brass screw/plug that you turn to get the car to idle? I just put one of these on my car and it FIXED all of my issues. I had to turn that screw about 6 full turns, though, from its factory setting.
    Feb 2009
    Latrobe
    517
    You Said Its A Mod Motor?
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
  1. Stall TC for AODE
    By J-rod in forum Ford Parts
    Last Post: 12-30-2013, 10:01 PM
  2. Stall in 11 5.0
    By scott5 in forum S197
    Last Post: 05-04-2013, 03:41 PM
  3. tci 3500 stall c4 24spline
    Last Post: 07-22-2010, 09:36 PM
  4. Looking to rent a garage stall near Crafton
    By PaceFever79 in forum Ford Parts
    Last Post: 09-25-2009, 10:16 PM
  5. Wtb A Stall Speed Convertor For C4
    By chuck94 in forum Ford Parts
    Last Post: 06-26-2008, 08:01 AM
