Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 459
Thread: Cobra Transformation...
  1. #201
    man i don't know 9 inches are so heavy , how much you taking off the rear for the mini tub mike 2 inches ?
  2. #202
    4,321
    It's not the amount of power in some cases, it's the application of it.
    Well put!
    I don't know from experience but I find it hard to believe that with all the light weight housing and hardware options for the 9" that you can't build one considerably lighter then your typical 9"? Possibly lighter then an 8.8 when it is all said and done? I guess we will find out! Not sure what I am going to do with the housing width just yet...
  3. #203
    robinson
    1,091
    physically a 9 inch can be lighter with fab style housing but take more power to turn them over a typical 8.8. but the gain in strength outweighs the loss in drag due to gear set.
    /twocents
  4. #204
    4,321
    Quote Originally Posted by bgblockelcamino View Post
    Thats what I would really like to know more about, make for some good testing on the dyno some day!
  5. #205
    1,037
    8.8 is a weak link. I have bent mine which is now braced up. Every set of gears is nice and quiet during the breakin. Then they get noisy after I hit them with slick launches. I had one set that was chipped. I am not the only one other there that has had issues with the gears not holding up. I use a solid pinion spacer.
    A 9" has a 3rd pinion bearing instead of 2 like the 8.8. I think that is where my problems arises. There is not doubt that something is flexing under load with the 8.8.
    Then you get into the talk of the weight and robbing power with a 9". I would think that a pinion that is not binding due to the additional support would be more efficient.
    When I replace my 8.8 I will get a Fab9 Housing with the anti roll bar and brace. Nodular Case, 3.50 gear, 35 spline axles, and the new wavtrac differential.
    It may weight a little more, but I will never worry about crap exploding again.
    2016 Mustang GT
  6. #206
    Quote Originally Posted by burntire View Post
    If I was doing one for a drag car I would consider 40spl gun drilled axles with a lightweight spool and a pro-gear gear set.
  7. #207
    I have many 9” setups laying around if you want to take one to compare. Buy light weight spool, sheet metal housing, and aluminum 3rd member.
  8. #208
    Monroeville
    856
    Any new pics Mike?
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
  9. #209
    never stock biminiLX's Avatar
    Beaver
    2,406
  10. #210
    i think i see it.. SOMEBODY STOLE HIS WHEELS!! haha
  11. #211
    4,321
    Quote Originally Posted by NateSVT View Post
    Any new pics Mike?
    They start cutting the car up next week Probably going to take a ride out in the next few weeks, I will take some pics then...
  12. #212
    Blairsville, PA
    378
    What in the world is going on now?
    2003 Sonic Blue Cobra - AccuFab Throttle Body, JLT "sonic blue" CAI, Diablosport Predator, 2.81 Pulley, 100mm Idler Pulley, Pro 5.0 Short Shifter, Bassani Catted X-Pipe, Bassani Cat-Back Exhuast, Eibach Sport Line Springs, FR500's, Corbeau A4 Microsuede seats, Sequential Tail Lights.
    1993 Ford Lightning - Gaylords Tonneau, LFP Traction bars, Eaton Posi, Cervini's Cowl hood + Roll Pan, Art Carr Valve Body.
    1995 F-250 PSD - Daily Driver
  13. #213
    4,321
    Quote Originally Posted by weareweird69 View Post
    Who knows, by the time it comes back it will probably be a low rider
  14. #214
    South Hills, PA
    4,052
    looks good man, I wanted to send my car to Dave, decided to tackle the mini tub and cage with wick, it may never get done LOL
  15. #215
    4,321
    I just don't have the time, experience or tooling to tackle this part of the project. I wanted it done right the first time by a proffesional who specializes in this kind of work. This car is going to be fast and it needs to be safe. Besides, it's nice not having it in the way at the shop
  16. #216
    South Hills, PA
    4,052
    cool man, i'm sure I will see you around this year at a show or track sometime, or a red light lol, good luck with build
  17. #217
    Anyone can restore em, But it takes a Real man to cut one Up!!!!
  18. #218
    1,037
    Is it going to be an 8.5 or 7.5 cage?
    2016 Mustang GT
  19. #219
    4,321
    I ended up telling Dave and the crew to 25.5 the car
  20. #220
    1,037
    7.5 it is.
    2016 Mustang GT
  1. 99 cobra heads 03/04 cobra crank
    Last Post: 04-07-2014, 10:40 PM
  2. My Kenne Bell 04 Cobra vs Gate's KB 03 Cobra.
    By NateSVT in forum Pictures & Videos
    Last Post: 07-13-2010, 07:15 PM
  3. WTB: 8 17x10.5 Cobra R or 03 Cobra wheels
    By Mark Aubele in forum Ford Parts
    Last Post: 04-26-2009, 01:12 PM
  4. WTT or sale 2003 cobra long block for 2001 cobra longblock
    By StreetLethal in forum Ford Vehicles
    Last Post: 01-17-2008, 06:51 PM
  5. Replies: 1
    Last Post: 10-06-2007, 10:48 AM
