Motor is just about done! Need to order an auxiliary idler and I'm going to replace the existing idlers with some better looking ones! I have 1 more bracket that I'm going to have Collins powder coat for me, need some breathers and waiting on the o ring gasket for the throttle body...still haven't decided on what I want to do about a tensioner.
Looks awsome mikey!!!!!!!!!!!
Pictures do not do this motor justice, one of if not the nicest builds I have seen!
See you tomorrow with the next bracket Mike.
Randy
The stang was on the back of a tilt bed broke down!![]()
Been slammed at the shop so I still haven't got much more done to the car. I did have Collins PC do a few more brackets for me, they came out really nice and completed the look of the motor! Waiting on a new FRPS and TPS and then I'm done with the motor for now. Should be able to get my car on a lift next week to plum the brake lines and to do a few other things. Then it's time to order some little stuff to get the tranny bolted up and then up in the car the power train goes![]()
I also uploaded a bunch of photo's to our facebook page. Most of them are probably on here but here is a link for anyone interested...
http://www.facebook.com/pages/Wolfpa...67049896653945
k & n oil filter looks out of place!!
I thought you where building a race car? It's looking like a show car!! Very nice!
It can defenately pull double duty, that's for sure!
Very sweet, gettin closer!
BTW, how are those brether's attached? I'm getting rid of my push-ins and want a screw in style.
Passenger side is a push in, here is the driver side...
http://metcomotorsports.com/proddeta...od=MBR0013%2D1
Thanks, very nice, what I was looking for, will weld on AN fitting to my VCs.
Some pics of the glide before I bolt it up...
