Results 1 to 8 of 8
Thread: 5.0 misc stuff
    Senior Member 89 vert's Avatar
    plum
    487
    5.0 misc stuff
    I have the following...
    1.306 block with rotating assembly inside, 1 broken piston on the top ring, e-303 cam 125.00
    2. stock heads, push rods and lifters 25.00
    3. stock water pump 10.00
    4. stock drive shaft 10.00
    5. stock alternator bracket 10.00
    6. Stock alternator upgrade to 100 amp 50.00
    Shoot me a PM if interested,, Thanks
    MSD ignition/King Cobra clutch/Polished Cobra upper and lower/Ported GT40p w RR/ 70mm tb/ 24 lb injectors/ pullies/ Mac cold air/ Mac long tubes/ H pipe/ 3:73 gears/ 3g alt/ welded sub frames/ Alum driveshaft/ CC plates/125 shot of juice/custom trunk/suspension goodies.
    FIRST PLACE 87-93 FOX BODY BUCKEYE STANGS SHOW 2010 AT SUMMIT RACING
    283 hp / 320 tq on mustang dyno (all motor)
    plum
    487
    Also have 30lb injectors 100$
    Stock air condition set up (everything in the engine bay) 75$
    2 JL audio 10 subs, amp, capacitor make offer.
    1 stock oil pump brand new make offer
    This engine needs 1 piston, there is no damage to the block, it ran good when it was removed. Can send cell phone pics if needed. Thanks
    plum
    487
    I can deliver if its not too far..
    plum
    487
    bump.
    Rollin in my 5.0 Shorty429's Avatar
    2,247
    I may be interested in the stock heads, depends on what i find i need for my car. Would you seperate with just the e cam?
    Black
    1998 GT- PI swap, 3.73's, off road h pipe, flows & some suspension goodies
    White 1986 GT T-Tops- BBK shorties, RAM clutch/flywheel, Bassani catted x pipe, MSD ignition, MAC cai, LMM lowering springs, adjustable skocks & struts, MGW short throw, DD
    Black 2009 Yamaha YZF-R6- custom levers, -1 front sprocket, Jardine GP-1 exhaust, HIDs, custom undertail, custom black windscreen.
    Pinks All Out #189 349Stroker's Avatar
    Petersburg,PA. 16669
    816
    what pistons,rods,and crank are in the 306?
    88 GT...and some boost
    plum
    487
    Just sold the block, heads, all that is left are the alternator and bracket and all the AC stuff.
    plum
    487
    and the 30lb injectors now 75.00
  1. Misc. Stuff
    By D1Mach509 in forum Ford Vehicles
    Last Post: 07-25-2010, 10:07 PM
  2. 5.0 misc stuff
    By 89 vert in forum Ford Vehicles
    Last Post: 02-28-2010, 11:37 PM
  3. 5.0 misc stuff
    Last Post: 05-09-2009, 09:10 AM
  4. More misc Stuff
    By Martin0660 in forum Ford Vehicles
    Last Post: 08-29-2007, 07:59 AM
  5. misc stuff
    By urgonnaluz2me in forum Ford Vehicles
    Last Post: 07-25-2007, 01:33 PM
