Results 1 to 13 of 13
Thread: 5.0 heads
    Jun 2008
    Bell Acres
    469
    5.0 heads
    Is there supposed to be a hole on the front of the e7's just like the hole on the back for the EGR tube? Mine seem to have one on the front and the back. I'm guessing the fronts need plugged too?
    Yes, the hole in the front is supposed to be there. When you bolt the acessories to the front of the engine, the bolts will plug the holes. Obviously if you plan to eliminate some of the factory acessories and are still left with the holes, you'll just need to find bolts that fit them to plug them up.
    Jun 2008
    Bell Acres
    469
    That's strange. My bolts for the Idler pulley/alternator bracket will not fit in the smog hole on that head. I didn't havea bolt in the other side with my A/C bracket(unless I lost it). Either way I would have to drill out both brackets to make a large enough bolt fit.... I'm confused lol.
    On the driver's side, the long rod that the power steering pump hangs on threads into a hole and one of the bolts for the alternator bracket goes in the hole on the passenger side. Are the holes too big fro your bolts? If so, there is a threaded insert that screws into the head that has a smaller threaded hole for your bolts to go into that would be missing from your heads.
    The threaded insert would like like these:
    http://www.fastenal.com/web/products...0123137&ucst=t
    I don't remember the exact size needed though.
    Jun 2008
    Bell Acres
    469
    Dang, how would I get/install two of those inserts? Would it be easier to just drill out the aluminum brackets and get larger bolts? I'm thinking so.
    Sep 2007
    Dayton PA
    3,795
    I have some in my old heads
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Polar Vortex
    6,031
    I had to get a couple once. I think you can get them through ford....I think.
    Sounds like you put the heads on backwards.
    shaler,pa
    1,010
    HAHAHA my first thought.
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Jun 2008
    Bell Acres
    469
    Nope, they already had the thermactor plugs in the back of the head that match the thread diameter on the front of the head. I was confused as to why the thread diameter on the front of the head was just as large as the back. Both the front and back also have the smaller diametr hole that holds the EGR pipe on the heads. I didn't think the heads I pulled off of the car had a port on each side.
    Why would these heads be symmetrical? Are they universal? The spark plugs only go one way so it almost seems as such.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Yes the heads are universal, no rights or lefts. That would cost too much for OEM production.
    http://www.summitracing.com/parts/TFS-51400265/
    BrandTrick Flow SpecialtiesManufacturer's Part NumberTFS-51400265Part TypePlug FittingsProduct LineTrick Flow® Small Block Ford Thermactor PlugsSummit Racing Part NumberTFS-51400265 Fitting Size 15/8-11 in.Fitting Attachment 1Male threadsHead StyleSlottedFitting FinishZincFitting MaterialSteelQuantitySold individually.NotesInside diameter is 7/16-14 inch.
    Mark Lowry
    Jun 2008
    Bell Acres
    469
    Oh, cool. I just ordered two. Thanks.
  1. GT40 3 bar iron heads,NOT P HEADS!
    Last Post: 07-05-2014, 02:14 PM
  2. what heads are these?
    By somethingclever in forum Fox-SN95
    Last Post: 04-11-2010, 05:59 PM
  3. Heads
    By ruger77 in forum Ford Parts
    Last Post: 03-02-2010, 06:48 AM
  4. PI heads
    By Mitternacht in forum SN95-New Edge
    Last Post: 08-11-2007, 02:57 PM
  5. 5.0 heads
    By eddmann55 in forum Ford Parts
    Last Post: 06-23-2007, 10:14 PM
