So after getting everything together and ready to go I was filling up the coolant and the engine starts pissing coolant from between the water pump and the timing cover. Ehh shit it's probably just the used water pump I put on there or me using silicone to seal the pump/backing plate.
Well after buying a new pump and putting it on... it's leaking between the pump and cover AGAIN. Only this time from both sides that have the coolant inlet to the timing cover.
Can rusted bolt holes in the timing cover cause this? One of the bolts was pretty shitty and snapped going back in (on the new pump, and probably why it leaked on both inlets to the timing cover instead of the one). Then after it started leaking I tightened some bolts down only to snap another one. Well it's getting a new timing cover for sure. But will this stop the leaks?
