Thread: 1 gallon fuel cell in engine bay
    Banned George C's Avatar
    1,490
    does anyone know the rule on this....i seen it on horsepower tv a while ago
    just wondering cause i want to run adecent N20 setup this year and didnt want to trust my stock fuel lines and etc. figure for NA my current setup is fine but figure when spraying i can have a fuel cell up frotn just to supply the fuel for the N20
    what are the rules on this
    I dont know what the rules are....but why not just "T" into your stock line right after the pump? Then you don't have to purchase and install another fuel pump for just the N2O.
    Not too mention the obvious fire hazard.
    1,490
    reason is the stock lines bcome a limit factor after a certain HP figure they say
    i want ot be able to hit it with up around 300 if needed to reach the goal.
    my current fuel setup is enough for all motor...for me to beable to run what i want ill have alot more money into the fuel setup to do it to support that amount of shot
    if i have a seperate fuel setup then i could only use it when i need to at the track...its going ot be pointless to hit it with any juice on the street with the new motor
    I think I would mount it somewhere other than under the hood.
    I still don't understand why you can't "T" into the line right after the pump..maybe run a couple feet of larger line out of the pump, then after the "T" is made, drop down to the smaller existing fuel line. Then run a new line up to the solenoid.
    Unless your pump isn't up to snuff...but it sounds like you feel you have a line size issue....not a pump issue.
    300 shot what are you trying to do run 10s in a truck
  1. Jaz one gallon plastic fuel cell
    By TooFast98Cobra in forum Ford Parts
    Last Post: 10-21-2016, 12:48 AM
  2. F/S Alum. 10 gallon fuel cell
    By TooFast98Cobra in forum Ford Vehicles
    Last Post: 01-23-2012, 10:15 AM
  3. Engine Bay
    By pop's stang in forum General Tech
    Last Post: 06-18-2011, 09:08 AM
  4. Uh oh,,,,,empty engine bay!
    By How Much? in forum General Tech
    Last Post: 03-12-2011, 09:09 AM
  5. need help cleaning up my engine bay
    Last Post: 09-28-2009, 09:38 PM
